Gotek not work
First post, by rain
hi i purchased gotek today but when instering usb stick gotek not dispaying any files . is it needed any attractions before use it like uptade firmware?
_retired retro pc user_
Reply 1 of 5, by Jo22
Hi, if you can, make sure it has Flash Floppy firmware or HxC firmware.
Both allow using floppy images (.img, .ima). The original Gotek firmware is horrible IMHO.
Edit: If it has Flash Floppy firmware, you need to use disk images. WinImage can make them, for example.
A pair of config file on the USB pen drive is needed, too.
Re: FlashFloppy, an open source firmware for Gotek drives
Reply 2 of 5, by rain
I put fdisk to usb stick to test gotek how to flash gotek btw
Reply 3 of 5, by stamasd
rain wrote on 2024-10-18, 16:04:
Depends on the Gotek model. Full information and instructions on the FlashFloppy site https://github.com/keirf/flashfloppy
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 5 of 5, by rain
yea im gonna use default firmware
