First post, by Omarkoman
hi
I am confused about which cache chips and TAG to get for a 486 motherboard.
this is the motherboard - https://theretroweb.com/motherboards/s/msi-ms … 131-vlb-486-al2
it says it can do 128bk and 256kb cache. Currently 4 of the 8 sockets are populated and shows 128bk cache.
is it best to get 8 of the same chip than mixing with what I have?
Would these work ?
https://www.aliexpress.com/item/1005007173170307.html
not sure what different there is between the UM61256FK-15 and UM61256K-15 in the listing?
Also what Tag chip do I need to use to make the 8 work and where do I get one ? eg what am I looking for on AliExpress ?
thank you in advance.
