First post, by Bholzwa
I just installed a 750ti in my zotac 9300 itx motherboard running windows xp. I'd like to use HDMI audio out through the card. With the latest xp Nvidia driver installed, I see Nvdia HD audio in my devices and it says it is fully operational. When I go to audio devices, there is only Realtek listed. Any ideas on how I can get the audio coming out through the 750ti?
Reply 1 of 12, by Rewound Gamer
Bholzwa wrote on 2024-11-21, 03:45:
I have the exact same problem, did you manage to solve it?
Reply 2 of 12, by GemCookie
I had the same problem and never managed to solve it. You might be out of luck with an Nvidia card – I had HDMI audio working on Intel integrated graphics and Nvidia's XP drivers are crippled in other areas.
Gigabyte GA-8I915P Duo Pro | P4 530J | GTX 750 Ti | 2GiB | 120G HDD | 2k/Vista/10/FBSD
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/OBSD
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/XP/NBSD
Reply 4 of 12, by Rewound Gamer
DosFreak wrote on 2025-07-06, 23:09:
Try installing the MS UAA driver KB888111. If the package doesn't install then extract with 7-zip and install manually.
Trying googling on this ... it seems this is supposed to be already included in XP SP3 so that wont work for me as I'm already on that version 🙁
Reply 5 of 12, by myne
There was another thread on this a while back. Not sure if it was solved but search
I built:
Reply 6 of 12, by ott
Rewound Gamer wrote on 2025-07-07, 02:22:
Indeed, the Microsoft UAA Bus Driver for High Definition Audio is already included in the WinXP SP3.
But here's funny thing: it doesn't install automatically, some trigger has to happen.
In my case it was a connected HDMI TV! I saw the UAA driver installation window for a second and WinXP detected a new sound device.
I noticed this behavior on the Sapphire Radeon HD 5670 with Catalyst 13.4 driver. I thought the UAA driver would be installed along with the Catalyst driver, regardless of whether the HDMI is connected or not.
The attachment uaa-bus.png is no longer available
I also have ASUS GTX 750 Ti, I'll try to check it later.
Reply 7 of 12, by marxveix
I dont know about Nvidia, but ATi/AMD usually has HDMI Audio separate drivers for XP, like for catalyst 7.11 its 7-11_xp32_hdmiaudio_54435.exe
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 8 of 12, by zyga64
Hdmi audio is working fine for me in Windows XP SP3 - I have GTX 750Ti with drivers 344.11.
However I had Radeon HD 7750 in this computer before (same Windows XP installation), so maybe it is the reason 😉
If there is anything I can check for you - let me know !
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 9 of 12, by ott
marxveix wrote on 2025-07-11, 17:59:
AMD HDMI Audio driver is already included in the newer versions of Catalyst (e.g. Catalyst v.13.4), I installed it together with the graphic driver. But the AMD sound device was not listed. Then I connected TV to HDMI (instead of my main DVI-monitor) and then everything happened as I described above.
Reply 10 of 12, by UCyborg
I have the same card by Gigabyte, NVIDIA High Definition Audio listed in Device Manager under Sound, video... and UAA driver among System Devices, though nothing in Sounds and Audio Devices in Control Panel. Not sure I have any HDMI cable at hand to see if anything changes if I plug through HDMI. Presumably it should show there regardless.
Driver version 355.98.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 11 of 12, by ott
I finally checked my ASUS GTX750Ti on a fresh WinXP SP3 install with NVIDIA 368.81 driver (Graphics Driver + HD Audio Driver) - it has the same behavior as on my previous AMD videocard.
  • Connected HDMI-monitor without audio capabilities doesn't trigger the UAA sound device.
    The attachment no-audio-device.png is no longer available
  • Connected HDMI-TV or HDMI-monitor with audio output triggers UAA sound device (NVIDIA High Definition Audio).
    So there is no need to install additional drivers or KB patches, HDMI audio works out of the box.
    The attachment nvidia-hd-audio.png is no longer available
Reply 12 of 12, by myne
Funny how
no x = no x
And
have x =have x
I built:
