First post, by Matth79
A mixed pile gave me a Ti4200 and a Radeon 9800 Pro.
I had a couple of old systems from friends, a Dell Dimension 8200 (late model, now upgraded to 2.8GHz 533) and a Socket A Athlon XP
I then got a HD3650 AGP (price was good) and though I needed a better AGP host, was hoping to go Core 2 but boards are rare and expensive
Found a cheap ECS P4M800Pro-M - unfortunately V1.0a, so no Core 2, upgrade that from the D915 with it to a D945 and found 2GB of low density DDR2
Got a slightly dented Coolermaster Centurion case and the board is in there.
Now I'm thinking, do I bother including the Unichrome integrated in any benchmarks - I thought Unichrome was higher up in the Chrome line, but seems it's only DX7 without Hardware T&L, not sure it could even participate in the same benchmarks... think I just talked myself out of bothering with that. Am I right, no more capability than ProSavage in earlier chipsets?
So then, the Ti4200 is DX8, the 9800 Pro is DX9 - and the HD3650 is DX10.1 - So I'd need Vista or 7 to take it to full capabilities, though it has XP drivers - I'm targeting an XP retro, though I never actually used Vista - wasn't impressed with it as an "upgrade" for my original XP system.
Half a mind to demote the Ti4200 to the Athlon XP and Win98, though my initial assumption was wrong, 98 does support DX9 (Dec 8 2006, vs Jun 7 2010 DX9.0c final for XP).
I doubt that any of the old game CDs I want to run would benefit from Vista, more likely to be a problem for any 9x/2000/XP transition era ones - ah, and it seems Vista would not use the hardware capabilities of the SB Live I've added - less CPU overhead than AC97, right?
