First post, by geertjanb
I have the feeling my
AMD K6-2 400mhz
Voodoo1 - 4MB
Matrox G100
128 MB SD-RAM
AWE64 GOLD
Windows 98 SE
is underperforming.
GLQuake at 512x384 does not run smooth, not perse low fps but many hickups.
Duke Nukem 3D at 640x480 stutters and hangs when starting up but once in game runs fine.
Grand Theft Auto in glide mode has some delayed control issues and in 24 bit mode it also stutters.
Outlaws seems to run fine.
I've read somewhere that it could be the polling of USB devices (both keyboard and mouse are usb) which slows things down.
Could it be a a bios setting? Or am i expecting too much from this machine?
Reply 1 of 14, by PC@LIVE
Maybe 🤔 it is not configured well, and some additional instructions are not used, or it could be the BIOS that does not recognize the presence, the problem can be easily solved, using specific programs, I would recommend Phil's benches, in his YouTube channel he talks about a recently updated DOS program, which you can find here:
https://m.youtube.com/watch?v=Po_oy7VjLu0
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 2 of 14, by stef80
@geertjanb
Which motherboard?
Reply 3 of 14, by Intel486dx33
For best hardware performance I would use
256mb SDRAM PC-133 ( 2x128mb )
IDE Compact Flash card as a Hard drive
SP3 core updates option
DirectX 9
In Bios you could Disable all ports not in use
Increase your Virtual memory settings in Win98
I like this one. Come with a bracket to mount in rear of case or in front bay.
Reply 4 of 14, by RetroPCCupboard
Intel486dx33 wrote on 2025-01-13, 09:27:
DirectX 9
Why install that when the "best" GPU in the machine only supports DirectX 6? Voodoo 1 is only DrectX 3 I think.
Reply 5 of 14, by Disruptor
Do you exceed the maximum cacheable area of your motherboard with that amount of RAM?
Reply 6 of 14, by BinaryDemon
Unless you are running some unofficial patch or engine update, Duke Nukem 3D doesn’t support glide or any other 3D api. Are you launch Duke3d thru Dos or with Win98 overhead? That almost rules out the Voodoo1 being an issue.
I’d do some general benchmarking as see if you can narrow it to CPU/Videocard/disk performance.
Reply 7 of 14, by Garrett W
Things to keep in mind:
- If you are on an Intel chipset, chances are your motherboard cannot cache more than 64MB. Check your motherboard and the chipset used.
- Yes, USB devices can be problematic. Get yourself a PS2 keyboard and mouse, disable USB controller in BIOS and try again.
- Do you use a HDD or some form of flash media? Do you have DMA enabled?
In general, you should try a few benchmarks to compare with other systems on here. But by all means, K6-2 400 performs roughly like a Pentium II 233-266 in most 3D games and the Voodoo 1 is also pretty slow. Don't expect more than 40fps in Quake 1 512x386 (less than 30 at 640x480!).
Duke 3D has some weird issues with sound stuttering, I wouldn't pay it any heed.
Reply 8 of 14, by leileilol
If you're running Duke3D under DOS, you'll probably want to run smartdrv beforehand (the specs leads to assumption of FAT32 here)
long live PCem
Reply 9 of 14, by havli
For best hardware performance I would use 256mb SDRAM PC-133 ( 2x128mb ) SP3 core updates option DirectX 9 […]
DirectX 9
Sorry but these points are all wrong.
Unless OP has one of the elusive MVP3 boards with 2MB of external cache or late stepping Aladdin V, then 256MB will be outside of the cacheable area and perform worse than 64 or 128 MB.
All the unofficial Windows 98 patches made things worse every time I installed them. So I definitely recommend to stay at vanilla 98SE install.
Voodoo1 and Voodoo2 doesn't like newer directX versions and it can cause trouble very often. For the best compatibility it is best to keep the default directX 6.1 or DX7 if you really need it to run some game... which is very unlikely in this case.
Also the latest Voodoo driver V3.01.00 didn't like K6-2 last time I tried. I suggest to use V3.00.01 instead. It lacks OpenGL ICD, but for Voodoo Graphics that is not very important anyway.
Reply 10 of 14, by Jasin Natael
havli wrote on 2025-01-13, 16:58:
Sorry but these points are all wrong. Unless OP has one of the elusive MVP3 boards with 2MB of external cache or late stepping […]
DirectX 9
Beat me to it, I concur 100%
Reply 11 of 14, by geertjanb
Thanks for your responses. To answer the questions:
It's a Lucky Star 5mvp3 rev 2.1 motherboard (theretroweb link)
For storage i use an IDE to compact flash adapter which reaches around 60 MB/s read speeds under windows 11.
In general the PC is very stable, everything just works. 3DFX, LAN, USB, MIDI.
It just feels like something is bottlenecking and causing stutters.
I will run the benchmark suit!
Also there is a lot to setup in the bios about ram timings (which are now set to normal), AGP Aperture size, AGP writeback, etc.
Reply 12 of 14, by geertjanb
Booted in (w98) dos mode:
Quake 1:
Software mode
320x200 = 969 frames 15.5 seconds 62.6 FPS
640x480 = 969 frames 50.4 seconds 19.2 FPS
Windows 98 SE:
3DMark01
800x600 @ voodoo1 = crash
640x480 @ voodoo1 = glitches = hang on test 14
800x600 @ Matrox G100 = 353 | 3D Marks - 4613 | CPU 3D Marks
In general i've noticed:
voodoo driver 3.00.01 = works
any other driver like 3.01.00 = crashes as soon as any 3Dfx game starts but monitor settings does show 3dfx logo.
Reply 13 of 14, by geertjanb
Could this be the issue?
file.php?mode=view&id=210165
Reply 14 of 14, by geertjanb
After enabling DMA
file.php?mode=view&id=210166
