First post, by Linoleum
I have an old ASUS CUV4X-C (https://theretroweb.com/motherboards/s/asus-cuv4x-c) motherboard that I believe might have been damaged due to a power supply issue. It was part of a system where the power supply may have been set to the 220V setting instead of the correct 115V. It gives absolutely no signs of life when I am testing it; PSU won't even turn on!
Visually, the motherboard appears to be in great condition. None of the capacitors have leaked, and there are no obvious signs of damage or burn marks. However, some of the other components in the system are confirmed to be dead: a Sound Blaster PCI 128, an ATI PRO 128 graphics card, and a Creative CD-ROM 52x drive.
That said, some parts of the system are still working. The P3 CPU (866MHz) and the floppy disk drive seem to have survived without issues.
Before I try to troubleshoot or repair it, I wanted to reach out to the community for advice:
- What are the likely components on the motherboard that might have been damaged due to this mistake?
- Are there any repair options worth exploring, or should I consider the motherboard a goner?
I’d appreciate any tips, testing methods, or insight you can provide. Thanks!
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 1 of 3, by dionb
Are you testing this with the power supply that may have been set to the wrong voltage, or with a different known-good power supply?
In any event, if you've found a PCI card, AGP card to be dead, what killed them came through the motherboard. If it was bad enough to cause that, it almost certainly did more damage. But that's an assumption. To be sure, start with checking for shorts between the power lines and continuity of ground and power to places like the slots and CPU socket.
Reply 2 of 3, by PcBytes
If the damage got to the cards, might as well call it game over. It most certainly zapped off the SIO, northbridge and southbridge as well.
Reply 3 of 3, by Linoleum
No worries, I didn’t even gave a chance to the old psu! I also tried a pci gpu…
That’s too bad because it looked like a good motherboard.
