First post, by alexparr
I'm not sure what type of RAM I need for this card... it has 1MB of memory currently so I assume each chip is 512K in size. I mostly just don't know what terms to use when searching for RAM; and typing the longer strings on the chips themselves certainly doesn't help in my search.
What kind of RAM is it specifically that I need?
Gateway 500S:
OEM Intel D845PT
Pentium 4 @ 1.80 GHz
256MB RAM
GeForce4 MX 440
SoundBlaster Live! CT4780
NEEDS MAINTENANCE
Pentimatum:
Gemlight GMB-P56IPS
Pentium MMX @ 166 MHz
32MB RAM
S3 Virge/DX
SoundBlaster 16 CT2230
Reply 1 of 6, by kixs
Check what is installed now and search for the same specs.
GM71C4260AJ70: 256K X 16 FAST PAGE DRAM, 70 ns, SOJ40
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 2 of 6, by myne
Cheap enough to gamble
https://www.alibaba.com/product-detail/GM71C4 … 0108400950.html
I built:
Reply 3 of 6, by alexparr
myne wrote on 2025-02-01, 08:43:
Eh, maybe? The site seems somewhat fishy overall.
kixs wrote on 2025-02-01, 08:38:
I found some NEC brand chips (UPD424260-70) with the same general specs. Will these work despite the difference in brand name?
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
NEEDS MAINTENANCE
Pentimatum:
Gemlight GMB-P56IPS
32MB RAM
S3 Virge/DX
Reply 5 of 6, by alexparr
DEAT wrote on 2025-02-02, 00:11:
Yes, there will be no problems there.
Alright, I placed an order for these chips. While I'm waiting for them however, I should ask which way they're supposed to go in the card once I get them. I noticed a slant on the chips themselves while looking at some images (which I assume is NEC's version of the typical notch) and a cut corner on the sockets; am I supposed to match these up?
Gateway 500S:
OEM Intel D845PT
256MB RAM
GeForce4 MX 440
NEEDS MAINTENANCE
Pentimatum:
Gemlight GMB-P56IPS
32MB RAM
S3 Virge/DX
Reply 6 of 6, by DEAT
Correct - I'm not aware of any 256K x16 SOJ-44 DRAM ICs that have text facing the wrong orientation.
win16.page | Twitch
