First post, by Half-Saint
- Oldbie
You will probably need the parity chips (the small sockets) populated, if not the complete bank filled.
Should be 256K x1 while the bigger ones are 256K x4.
Another solution If RAM chips installing/configuration is still failing:
The signals at the pins of the SIPP RAM module match those at the contact pads of the SIMM RAM module. So you can turn any SIMM memory stick into SIPP memory stick simply by soldering pins to its contact pads.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
