First post, by dely
Forever Party 2025 featured the launch of my new text adventure game Tale of Ancient Land. It is most likely the first game for CP/M in decades, and is set in the ancient times of pagan Eastern Europe and modelled on the once popular MUD-type pastimes - we take on the role of a traveller who is faced with the task of acquiring four artifacts of power.
The program is multiplatform and is written for CP/M 2.2 (works with CP/M 3 too), so it runs on virtually any 48 KB TPA computer that can run this operating system.
The games was tested on various machines including:
  • Commodore 128
  • Amstrad CPC 6128
  • Elwro 800 Junior
  • BOSMAN-8
  • Indus GT (disk drive for Atari 8-bit computers)
  • Atari 1090XL replica
  • SVI 738 (MSX)
  • ZX Spectrum 128+3
  • FDD 3000 (disk drive for ZX Spectrum / Timex computers)
The sources, as well as ready-made disk images for various systems, can be downloaded from the repo https://gitlab.com/delysio/adventure/
Reply 1 of 7, by bakemono
Turbo Pascal programs never work on my Z280, this confirms it. A new release without 40 years of bitrot also silently returns to the command interpreter...
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 3 of 7, by Robbbert
I don't have any of those computers, so I tried the Amstrad CPC 6128 in an emulator (MAME), but without success.
The issue is that because it's a CP/M program, normally on the CPC you'd enter |CPM and then it should run the program, however it says the disk is unreadable. If I don't do |CPM, then CAT will list the files, but of course it isn't possible to run .COM files in this mode.
I also looked at the msx disk, but MAME doesn't support .IMG files for MSX or the SVI-738.
Reply 5 of 7, by bakemono
dely wrote on 2025-03-18, 18:53:
Can you check on your machine and send the result of the SURVEY.COM application?
https://retrobrewcomputers.org/n8vem-pbwiki-a … 00862/index.htm
This program runs, and the memory map looks correct, though it doesn't seem to handle harddisk partitions correctly.
For the |CPM command to have an effect, you must have a system disk with CP/M. For obvious reasons, I should not distribute the game with the operating system, which is copyrighted.
Anyone who would like to obtain CP/M should take note of this statement by the president of DRDOS (owner of Digital Research IP) http://cpm.z80.de/license.html in which permission has been granted to distribute and modify CP/M. OEM copies, customized for specific hardware, might be hard to find and might contain software copyrighted by other entities. CP/M itself though is in the clear.
    66.62 KiB
