First post, by kanyero
Hi.
I would like to build a p4 for late ms-dos games and win9x games. I need a compromise between those two OS.
More or less i´ve decided all components but the sound card.
I must choose between a sound blaster live 5.1 PCI and a Terratec Aureon 5.1 PCI.
Wich one do you think would be better mainly for DOS ?
Thanks a lot.
Reply 1 of 5, by Linoleum
Isn't the Terratec Aureon SB 2.0 and SB pro compatible only? While you'd be getting SB16 + General Midi (+MT32) emulation with the Live. Seems like a pretty obvious one to me... Unless I am missing something?
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX4 100, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 2 of 5, by mockingbird
If the Aureon uses the CMI8738, then don't plan on playing anything in pure DOS...
(Decommissioned:)
Reply 3 of 5, by PcBytes
Aureon 5.1 is 8738. I know a friend who still had one and it uses a 8738 chipset so I wouldn't count it to do DOS even if its life depended on it. SB Live will do it just fine.
Reply 4 of 5, by kanyero
Understood, no Terratec for dos.
Does Terratec Aureon 5.1 PCI have any advantage over live in win9x ?
Thanks
Reply 5 of 5, by Linoleum
kanyero wrote on 2025-04-04, 07:31:
Thanks
Maybe if you have it connected through optical output to a receiver... Which would require Live Drive or a daughterboard for the Live! card.
