First post, by Kaegan
Hi, I'm having trouble loading up PowerDoLLs 2 on a p4 @ 2.9 with 1 GB memory, on Dosbox 0.6.3. I can't get past the splash screen.
The error message I get is CPU:GRP 5 Illegal call 7 while I try to run the game while the CPU is in any mode but dynamic. When I set it to dynamic the error message is Illegal option instead.
Messing around with memory/audio/cycles doesn't seem to yield results. I've noticed that there have been other games with this same error message, and I've tried their solutions as well, but none of them seem directly addressing this particular error. Any help?
Thanks.
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
I think this is fixed in the CVS (see the dev forum).
Reply 2 of 5, by Kaegan
Which version? I just tried using the ones offered over at that german webpage, same results.
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Hm, try to mount some directory as a cdrom (see the readme),
i think this was needed for this game additionally.
Reply 4 of 5, by Kaegan
I'm now using the 200/11/15 CVS from ykhwong. When set to dynamic, once again, it returns an invalid option. When set to any other mode, the error message returns the same, Illegal call 7.
Could you elaborate on mounting "some folder" as a cd-rom? I know how to do it, but I'm not quite sure what difference that'd make.
Reply 5 of 5, by Kaegan
Aha! Got it working. You were absolutely correct. I loaded up the game directory as a CD-rom and it ran past the crash-point.
Thanks!
