Gavrilo wrote on 2025-05-10, 10:52:
Hello guys, I would like to ask if I can put without a risk Intel 80386DX with 25MHz, which I saved with other stuff from malfunctioning Joindata Systems Inc. G386SYM, into very rare socketed version of Octek Jaguar C-V motherboard, where should go 40MHz processor. Thanks.
Huh, I was going to say it could work if the board had a PLL so you could set the clock.
But looking at the board picture you've attached, your board has a 66MHz clock crystal and no PLL. Meaning that the CPU is already set for 33MHz operation and can't be easily changed, a 25MHz 386DX should do 33MHz probably? So it should be safe to try as-is 😀
Looks like some corrosion needs cleaning around the clock battery area and that original NiCD / NiMH clock battery should be removed.
Be careful of the pin1 orientation since the CPU is not keyed.
