First post, by lackofpatience
- Newbie
Hey people,
I have a bit of an odd one. I'm looking at having a go at building the following.
https://github.com/Marco-Both/M396F-Replika/t … ov-file#topview
It's based of the following motherboard. And uses a SARC RC2016A5 Chipset
https://theretroweb.com/motherboards/s/pcchips-m396f-v2.2
The problem I'm facing is that SARC chipset is no longer available. From my best research on the following links, it's based on another type/brand.
Identifying PCChips 386 era chipsets
https://dosdays.co.uk/topics/Manufacturers/pcchips.php#m396f
These 386 SX boards also appears to use other models of the chipsets, RC2016A4, RC4018A4 but these are more 386DX Chipsets.
Would anyone know what other chipset's I might be able to use as an alternative?
I was hoping to find another QFP 208 pin chip and compare the pin out to the diagram I found for the project here:
https://github.com/skiselev/mb386sx-rc2016/bl … hematic-1.8.pdf
Cheers!
Mitch
