First post, by Nehalem501
Hello everyone,
I’m looking for recommendations for a cooler for my old childhood PC.
It’s a socket A machine with an Athlon XP 1400 (if I remember well) and the stock cooler.
When I used this computer at the time I didn’t notice the noise as much, but I guess I’ve been spoiled by modern PC hardware since. What I’m looking for ideally is a cooler I could use with a modern 120mm fan that would be as silent as modern PC coolers. As the GPU is fanless and I will be replacing the HDD with an SSD, the stock cooler is main culprit when it comes to noise.
I’ve looked a bit at older threads on this subject, and they all seem to point to coolers that are visually similar to the stock cooler with tiny fans. Tiny fans that rotate at a high speed are not really compatible with my goal of relative silence.
I’m not very knowledgeable about PC hardware from this era outside of the main PC components as I’ve really started to get into the hobby during the socket 775 / core architecture era.
I don’t really plan to overclock the CPU, but I might upgrade it some day.
My motherboard has cooler mounting holes around the CPU socket.
Also, I’ve noticed that the connector on the motherboard has 3 pins, how does that map to the 4 pins of the more recent CPU cooler fans? I can build an adapter if I know which pins have to be connected.
Thank you for your help.
