First post, by Vendein_RaZoR
Do you have 580VPX motherboard build with K6-3 chipset?
I have modified K6-2+ to K6-3 CPU with 256 KB cache, but i have no changes in performance in comparison with K6-2+ 128 KB CPU.
Why ? Any guesses ?
Reply 1 of 3, by rmay635703
Have you run the k6init applications and run the memory bandwidth tests
Reply 2 of 3, by Repo Man11
The difference in performance isn't huge, but it's generally measurable - what benchmark(s) are you using to test for the difference?
Reply 3 of 3, by nickles rust
It depends a lot on what software you run. I measured over 200% difference in speed, just by changing the cache configuration on a K6-2:
www.vogons.org/viewtopic.php?t=88437
