430VX cache size
First post, by GoldenPentium
Hello everybody,
I have 5I-VX2B motherboard (430VX) with 256KB cache (2 chips Galvantech GVT7132C32Q-7) on it. Is that possible to twice the size by replacing them by some analogs? If yes, which chips should I look for, is there any other remediation to the board (I mean, additional capacitors, resistors etc)?
Reply 1 of 20, by majestyk
The VX chipset can handle 512K L2 cache but it´s also limited to 64MB cacheable RAM area. The question is if 256K ist sufficient to max out those 64MB or if 512K have any benefit at all.
You should populate the board with 64 or 128 MB RAM and run a tool like "ctcm7" - this will tell you if there´s a 64MB cached area or if there´s any non-cached area.
If ctcm7 finds that the cacheable area is for example only 32MB it would be useful ton replace the cache chips. Otherwise it´s a waste of time.
Reply 2 of 20, by weedeewee
wouldn't the cacheable area be determined by the tag ram size ? ie. the ISSI chip between the NB & SB.
Do not ask Why !
Reply 3 of 20, by GoldenPentium
majestyk wrote on 2022-06-11, 16:14:
I see. ctcm on my 64MB saying "no noncacheable Areas found" - does it mean that everything is maxed out and there is no sense to upgrade board at all?
Reply 4 of 20, by majestyk
TAG-RAM size and organisation must match the respective L2 cache-size of course.
The cacheable area is limited by the chipset here. Intel 430 VX has a fixed limit of 64MB, same goes for 430FX and even the later 430TX. Only the (more enterprise) 430HX provides 512MB cacheable area under the conditions that you have 512k L2 cache and 2 (two!) TAG-RAM chips.
Generally the amount of necessary L2 cache for a given cacheable area depends on the chipset design, cache-policy, write-back/write-through etc.
"No non-cacheable areas found" means that - under the current cache-policy etc. - 256K are all you need.
Reply 5 of 20, by pentiumspeed
No. All Intel chipsets for socket 5 and 7 caches up to 64MB with a exception: HX chipset with 11 bit tag sram (two tag sram chips) can cache up to 512MB.
Cheers,
Great Northern aka Canada.
Reply 6 of 20, by Anonymous Coward
LX caches up to 192MB, and NX up to 512MB...if you dare to use them. LX was mostly socket4, but I think there were a few used on socket5 too...right?
Reply 7 of 20, by Sphere478
-Max ram is 128mb
-Max motherboard cache is 512k on motherboard +\ or coast
Max cachable is 64mb
I once tried to get more ram than 256mb in a 430tx mobo and it failed. There doesn’t appear to be any way to do it, and I expect it’s the same case with the 128mb limit of 430vx
I don’t think there is a way around the cachable area (except the way I will discuss in a second), but majestyk is probably the one to talk to about that.^
The 512k I’m pretty sure with the right chip and configuration you could achieve. You would have to study the traces and the datasheet of some 128KB modules.
Okay, here is the thing though,
That cache probably doesn’t even matter because if you use my method you might disable it anyway (and be faster for it) though testing will determine that.
Anyway, I speak of course of the k6-3, the k6-2+ and the k6-3+
With these cpus the caching problem basically goes away.
Ultimate retro link btw. Let’s be sure to fix any errors in the listing with info we learn here.
https://www.ultimateretro.net/en/motherboards/3482
Does yours have one or two heatsinks below the cpu?
If one then your fastest cpu is a mmx overdrive 200 or if you wanna get janky, you could do a k6-233.
Any more than that and you’ll need a power interposer. Or to supply voltage to the traces that appear to be present on the mobo for vcc2
More info
https://www.anandtech.com/show/72/7
Sphere's PCB projects.
Reply 8 of 20, by GoldenPentium
Sphere478 wrote on 2022-06-12, 02:23:
My mobo does have two heatsinks, so I am good to go with 233 CPUs.
Reply 9 of 20, by Sphere478
GoldenPentium wrote on 2022-06-12, 02:53:
That’s great news.
Actually I was thinking more along the lines of a k6-3, k6-2+, or a k6-3+.
Are you open to that? You would probably be able to reach 400-500 mhz with one. And your cache issue wouldn’t be a problem anymore because of the onboard cpu cache.
Can you measure the middle corner pin on the cpu socket using a resistor leg to ground (black wire on psu connector, or the case) without a cpu in it when all of your voltage setting jumpers are removed?
Reply 10 of 20, by GoldenPentium
Sphere478 wrote on 2022-06-12, 02:56:
73-75 Ohm, if I measured it in a right way.
Reply 12 of 20, by Sphere478
I think I figured out the answer though. Were I not tired last night it might have been obvious to me, Your heatsinks are large and that suggests linear regulators. And obviously the lack of inductors does as well.
And the manual has options down to 2.5v
This is low enough for a k6-3
Not a k6-2+/3+ Though.
You can map your various resistor combinations and see what you can come up with though as far as undocumented settings but if that doesn’t work. With some resistor mods you may be able to get to 1.9-2.1v which is where a 2+/3+ would be happy. If you want to look into that then you’ll have to check specs of your regulator controller, and regulator and find the resistors responsible for making the voltage setting and change one to one you want or make a jumper with one on the jumper if higher resistance is a option.
In any case, 2.5v will be enough to accomplish your goals.
You will want to watch the regulators for heating though. Be sure they are cooled.
Unless you want to go for a 2+/3+, your next step is to find the 2.5v setting, order a k6-3 and get a bios update from the diy modding support thread and you should be good to go.
Re: Diy modding support for k6+And 120gb hard drives into bios roms
Reply 13 of 20, by rmay635703
I’ve exceeded motherboard memory limits in the past.
In a few cases the board would count the extra memory but not use it.
I had a later IBM 286 of some sort with 20mb installed it counted up but still a tad less than 16mb was usable
Reply 14 of 20, by Sphere478
rmay635703 wrote on 2022-06-12, 17:49:
My 430hx tyan can count 768mb and post but when it tries to use it the system crashes.
Another user around here was able to get 384 on their 430tx mobo but same problem.
In both cases memtest says all is well.
The only way you can see the issue is to fill up the memory with unique data. Like unpacking driver.cab usually does the trick. Trying to install windows or a OS also usually fails half way through.
This is because detecting and being able to use aren’t the same thing.
There may be mobos that will allow the usable memory only to be used but these two examples led to a unstable system. Removing the unsupported memory solved the peoblem immediately.
Reply 15 of 20, by weedeewee
fyi, a 286 can only have 16MB total memory (EMS not counting), of which some is used for ROMs and some VGAs might use 1MB for Framebuffer from 15-16MB (i've read somewhere)
Do not ask Why !
Reply 16 of 20, by nickles rust
Looking at different pictures of coast modules and motherboards, I think you could replace the 3 SRAM chips and move a jumper to upgrade from 256kB to 512kB. For example, compare these two coast modules:
The attachment coast.jpg is no longer available
Reply 17 of 20, by nickles rust
In some cases the cache setup can make a big difference. Here are some test results for gcc compiling under linux on my PCchips M530 (430VX) with 128MB of RAM, 450MHz (75x6) K6 CPUs, and different coast modules. Everything is scaled vs the slowest configuration and you can see that big improvements are possible by simply changing the cache.
The attachment k6coast.png is no longer available
The BIOS for the K6 on the M530 is from this thread:
www.vogons.org/viewtopic.php?t=73635
Reply 18 of 20, by rmay635703
Anonymous Coward wrote on 2022-06-12, 02:04:
And then the question of whether a slow memory controller, FPM and non-pipeline burst (async cache) makes the additional memory worthwhile
I’ve actually tried to find a LX board that officially supports 192mb and all I’ve seen mention 128mb, so I sort of wonder which spec is correct.
K6-3 and 2+ should solve cache issues.
Gotta wonder what a 2+ would do to the Lx/NX with slow ram/cache? Might really wake it up
Reply 19 of 20, by dionb
Just look for any with 6 SIMM slots, like the Asus PCI/I-P5MP3. The chipset support max 16Mb chips, so 32MB per DIMM. Use six of those and you get 192MB by . But that's So4. i430LX has 5V I/O, so to use it with So5 with 3.3V I/O you'd need to convert all signals from one voltage to another. It has been done - AIR and Tyan had So5 i430LX boards complete with a pile of supporting ICs for that voltage stuff - but it begs the question: why? i430NX implements all features of i430LX at 3.3V, then adds an extra memory row and SMP support as well.
As for K6-2+... the mind boggles. Slow cache will indeed be solved by on-die cache, but the (by Super Socket 7 standards) glacially slow FP memory controller will bottleneck it hopelessly, if you can actually get it running.
