First post, by LoStSOul
Hi everyone,
Anyone have this soundcard ? i didn't found this exact model (with good quality) on web, there are some variants very different from this..
I will try to repair, at first look there are missing crystals and capacitors
X3 - 24.576
GamingPC: R7 9850x3d, x870E Aorus Pro,32gb, radeon 7900 xtx
DOS/Win95: P1 233MMX, 32MB ram, Sb AWE32 2MB mod, 3dfx voodoo1, S3Virge
Win98: P2 450Mhz, Matrox G200, SB AWE 64Gold
WXP: Dual P3 1Ghz, Abit VP6, 256Mb , SBLive, geforce256 1 ddr
Reply 1 of 16, by Tiido
You need 16.000MHz for the CS9233 and 16.9344MHz + 24.576MHz for the CS4248. The small capacitors can all be 10µF and sound will come out fine (original likely had a number of 1µF ones but that is only gonna limit low freq response). The two larger ones near outputs should be as high value you can physicall fit since that determines the low freq response, 220µF and higher is the ballpark there.
Reply 2 of 16, by LoStSOul
Tiido wrote on 2025-07-20, 18:06:
Thanks!!!
any ideia of top crystal X1 near DSP-9410A ?
Reply 3 of 16, by keropi
LoStSOul wrote on 2025-07-20, 20:20:
Thanks!!!
there are some close-ups here: https://retrosoundcards.wordpress.com/categor … allant-sc-8000/
X1 is 16mhz xtal
Reply 4 of 16, by Tiido
It is probably 12, 16, or 24MHz, like seen on Creative cards and many other clones.
EDIT: it is definitely a 12MHz ceramic resonator that is supposed to go there.
Reply 5 of 16, by keropi
there is a high res pic here: https://allegro.pl/oferta/isa-crystal-cs4231a … oxz-17487770525
but I have found no easy way to save it ... it does show that X2 is 12mhz though
Reply 6 of 16, by LoStSOul
my bad, X2 near DSP
Reply 7 of 16, by keropi
LoStSOul wrote on 2025-07-20, 21:58:
my bad, X2 near DSP
Like Tiido wrote it is a 12mhz ceramic resonator
Reply 8 of 16, by Matth79
Some view source and save
Reply 9 of 16, by weedeewee
keropi wrote on 2025-07-20, 21:01:
in firefox 140,
click on the lock icon left of the URL in the address bar, then
click on 'connection secure', then
click on 'more information', then
click on 'media', then
sort by size,
select the biggest image in this case and click on 'save as' to save a local copy.
Or right click and select 'copy' to get the link
https://a.allegroimg.com/original/112535/b4db … HOOL-100-OK-OxZ
Do not ask Why !
Reply 10 of 16, by keropi
weedeewee wrote on 2025-07-21, 07:37:
in firefox 140, click on the lock icon left of the URL in the address bar, then click on 'connection secure', then click on ' […]
in firefox 140,
sort by size,
Thanks for the tip!
Reply 11 of 16, by LoStSOul
I think i have all information to try revive this card 😁
thank you guys!
Reply 12 of 16, by keropi
LoStSOul wrote on 2025-07-21, 18:53:
thank you guys!
good luck!
post progress!
Reply 13 of 16, by LoStSOul
Well... need to do few visual checks and to confirm there aren't short circuits
Let's see if work, doesn't work or smoke everything
Reply 14 of 16, by Tiido
You may have to change the capacitors near the 12MHz crystal. Original was a ceramic resonator and those often use much higher value capacitors there which will make an actual crystal you use unable to start oscillation. If the card appears not to work, this may be the cause. Exact value depends on particular crystal used but the general range is between 10 and 33pF. Nice work though ~
Reply 15 of 16, by LoStSOul
Tiido wrote on 2025-07-26, 19:47:
found smd broken cap shorting, but don't seem to be critical at moment (removed cap)
well... the card don't work..
Voltage Regulator, in: 12v out 5v
3 crystals look oscilating normally, X3 24.576mhz does not work, even after replace
Reply 16 of 16, by Tiido
the 24.576MHz is only used for 48kHz based sample rates and I thinkit only comes to life when such a sample rate is being wanted to be played.
The ISA pins look full of corrosion dots, it is worth to shine them up also. Rest of the card looks like nothing is broken, at loast on the top side... Perhaps there's also a loose pin on the CompuMedia QFP, needle test (skating one across all the pins) will reveal all such pins quite easily.
