First post, by SufferWell1396
Hello, all! I've recently purchased a Tualatin with an on chip adapter https://www.ebay.com/itm/281238323137 for use with my ASUS CUV4x. I've also installed the modified BIOS found here Modified BIOSes for ASUS P3B-F, P3V4X, P3V133, CUBX, CUBX-E/L and P3C-E
The board is not stable at the rated 1266 MHz and will fail to boot at 1.4, 1.45, and 1.5V. At 950MHz and 1.45V, it's possible to get into Windows, but as soon as you do anything remotely intensive the system hangs. I've monitored temps and the chip is never going over 45C, at least reported by the board itself.
Has anyone had any experience with these chips? Any recommendations?
Reply 1 of 5, by LoStSOul
maybe some capacitor with problem
GamingPC: R7 5800x3d, x570s Aorus Elite ax,32gb, radeon 7900 xtx, w10
InternetPC/General use: R7 1800x.64gb, Asus prime x370, quadro p620, Debian12
Reply 2 of 5, by SufferWell1396
Would the board potentially have bad caps even if they're not showing signs of wear? I've never recapped before but have a good friend that can help me, and I know the CUV4X is known to have caps issues (alongside everything else in the P3 era). I took the board out today to clean it and there was no leaking or bulging, but I suppose that doesn't necessarily mean one or two haven't gone bad.
Reply 3 of 5, by Archer57
This hardware is old enough at this point that any caps, defective or not, can be bad. If you have a reasonable suspicion probably the only way to be 100% sure is to do some "exploratory surgery" - desolder a cap or two and check them in a tester.
In my experience if they look fine they are often fine, but not always - i've seen completely dead caps with no visual indications...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 4 of 5, by SufferWell1396
I think that has to be the issue here. I've added nothing new and the system will randomly completely lock up - now even after replacing the Tualatin with the Coppermine it originally had. With that in mind, is there a good resource for what caps I might need? Where should I get them from?
Reply 5 of 5, by LoStSOul
my last order of components was from mouser.
Memory errors, cpu errors are most the time caused by bad capacitors. "it runs fine with 1 stick of ram, add another and crashes, freeze.."
