First post, by zwrr
- Member
My friend gave me an AWE64 Gold, model CT4390, which is a faulty card. The problem is that the left channel is normal, but there is no sound output on the right channel. I tried to connect the left and right channel outputs of TDA1387 directly to the speakers, but there was still no sound output on the right channel. Then I replaced the TDA1387 chip and repeated the previous test, and the result was the same. Does this mean that there is no right channel data in the digital signal output from CT8903, which means that the CT8903 chip is damaged? I don't understand the structure of the AWE64 sound card. If it is a fault of CT1703 or CT1745A, will this result result?
I hope someone can tell me the next step for repair.
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
