First post, by Intel486dx33
Guys,
The creative Audigy 2zs is the best sound card for retro computers.
I have been using it since Win98
I am still using it today in my HP computers running Win-10 and Win-11
Although I now use the Creative USB DAC GC7 too.
The Audigy 2zs still works I keep it for its input/output options
Works with PC and Linux
No online app or online connection required.
Reply 1 of 17, by bertrammatrix
Intel486dx33 wrote on 2025-08-22, 15:58:
Guys, the creative Audigy 2zs is the best sound card for retro computers. I have been using it since Win98 I am still using it t […]
The Audigy 2zs still works I keep it for its input options
Blasphemy! When it comes to retro sound it's ISA based or nothing 😀
But I suppose when it comes to pci you are right. It was easy for creative to win, after the pitiful 128 and original Live everything else was pretty decent, and really no serious competition after a certain point.
Reply 2 of 17, by AncapDude
Audigy2 ZS is definitive my loved one. Very good looking, crystal Clear Sound and runs fine on Win98 with SB16 Emulation and Wavetable.
For ISA i like the AWE64 most. I buyed also a SIMMconn Module for one just to find out it doesn't Support SF2 on Plain DOS. What a shame. But luckily we have VSBHDASF which brings me back to the Audigy2 ZS running in Plain DOS with loaded SF2. Even huge fonts >100mb are working. I really Miss this on AWE cards.
For 8bit I would chose an SB Pro 2.0
Reply 3 of 17, by Intel486dx33
This card is a legend.
Produced in September 2003 it is over 20 years old and will still work for another 5 years.
This card definitely belongs in your collections.
Reply 4 of 17, by Azrael128
What do you mean, "retro"?? I'm still rocking it in my latest-gen, productivity rig (and I wish I had that front panel so I could record in 96KHz). It's actually still a remarkable card for modern use-cases once you figure out the PCI compatibility issue.
I maintain that the stuff you can do with the kX drivers and this sound card is impossible to do with any modern hardware whose cost is below four digit.
Reply 5 of 17, by ott
Azrael128 wrote on 2025-08-23, 04:37:
Original Audigy 2 panels are quite rare, but X-Fi I/O Drive (SB0251) panel is compatible with Audigy 2 ZS (SB350).
Everything works except FireWire.
The attachment xfi-panel.png is no longer available
What are advantages of kX driver on Audigy 2ZS? As far as I understand, it about additional audio effects and routing?
Reply 6 of 17, by pete8475
I use Audigy cards with optical out for clean sound on most of my retro machines. It's pretty easy to connect generic optical headers to the cards so that's usually what I do.
Audigy Optical Out to main PC
Reply 7 of 17, by Intel486dx33
Yeah,
All the ports work in Win-10 and Win-11
Even Firewire. Everything works on my HP z440
Oh, I don’t know about the remote I never tried it.
Still sounds Great.
Reply 8 of 17, by Intel486dx33
I bought another one because I need one for my other HP z440 computers.
What is a PCI slot for ?
Reply 9 of 17, by Azrael128
ott wrote on 2025-08-23, 07:56:
Yes. It gives you total access to the DSP to route signals as you see fit, and put any effect (as long as it fits the DSP) in between, to any or all parts of the signal. It also allows for real time monitoring of the input, and "what you ear"-like recording, both of which are far from guaranteed in motherboard chipsets nowadays.
It also generates several virtual output devices in Windows, which allows you to assign different software to different outputs, which will then enter the DSP from different ends, allowing you to route and process them separately.
For example, you could have:
- Winamp goes to Windows device WaveOut 0/1
- VLC goes to Windows device WaveOut 4/5
- Game you're playing goes to Windows device WaveOut 6/7
In the DSP, you can then:
- Take WaveOut 0/1 as your input, add an AGC to it, and route it to a mixer plugin
- Take WaveOut 6/7, route it to the mixer plugin, no processing
- Take WaveOut 4/5, route it directly to one of the physical outputs (say: front left/right)
- Take your mixer plugin, which now has the sound from Winamp and your game, and route it to another physical output (say: rear left/right).
Now you have two distinct sources of audio, which you can route to different inputs of a real mixer console, allowing you to adjust the volume of VLC and your game/winamp separately, directly from your deck.
You add a microphone to your mixer console, and send everything back to the Audigy's line in.
Then from the DSP again, you take the line in, you may add a final processor plugin (e.g. a limiter) for the complete signal if you wish, and send it both to "Recording Mixer" (WASAPI/MME recording device, to be used by software such as Discord, OBS or whatever), ASIO in (for your DAW if you have one, or for further sound processing), and finally, to the last available physical output on the Audigy (center/sw), to which you will plug your headphones for monitoring, allowing you to monitor the signal at its very last stage, exactly as it is sent to OBS, with zero delay.
Have a change of heart? You can make a completely different workflow.
Say you want to be able to send someone your voice and music via Discord, hear them back, but make sure they don't hear themselves in echo:
- Send Discord to WaveOut 0/1
- Send Music to WaveOut 4/5
- Send your microphone through line in or mic in
In the DSP, mix together your microphone with WaveOut 4/5, but not WaveOut 0/1 (Discord) and send it to the WASAPI/MME recording device. Because WaveOut 0/1 is not part of the signal sent to the WASAPI device, your friend won't hear himself back.
Then make a second, parallel mix in the DSP, mixing together all three sources and send the result to whatever physical output you have your headphones plugged in: you hear everything, including your friend.
Lots of other things you can do (e.g. take a signal, split-band it, add a compressor to each band, then mix everything back together to create a real time, hardware-accelerated multiband compressor). It really is an audio nerd dream.
You can, of course, save and load your various DSP workflows depending on your needs of the moment, it's basically a single click thing, no need to reset the driver or anything.
Three important caveats however:
- No EAX (I think there's very partial support for EAX2.0? But I'm not even sure).
- No MIDI synth compatibility on x64 Windows due to a bug in the driver
- kX is compatible with the p16v chip (Audigy 2, Audigy 2ZS) for up to 24bit/192KHz playback/recording, but not with p17v (Audigy 2 Value, Audigy 4/4Pro, Audigy Rx). So these later models are limited to 48KHz/24bits under kX.
Reply 10 of 17, by ott
Azrael128 wrote on 2025-09-27, 18:49:
Big thanks for the detailed answer, these are impressive features!
Reply 11 of 17, by Intel486dx33
On the ISA side just get a
Sound Blaster Pro 2
or
Sound blaster Vibra 16c
And you are Set.
They are Plug-n-play
And easy to setup.
Drivers are included in Windows installation disk
These are the Sound cards I would put in my Computers.
Reply 12 of 17, by Shponglefan
ISA Sound Blasters tend to be a hot mess of bugs, noisey outputs and middling features. The AWE64 cards and the CT3670 SB32 can be worth using for native SB16 and AWE32 support with clean output. And some of the SB16 line have Yamaha OPL3 and less noisy DACs.
Beyond that, there are much better ISA sound cards than most Sound Blasters. Especially if one wants bug free MIDI wavetable support.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 13 of 17, by Intel486dx33
Oh Yeah, The AWE64 has a Clean sound and works the AWE32 driver included in Win95 install disk.
I was just refencing ISA sound cards with drivers included in Win3x, Win95, Win98.
For EASY installation and setup
Also include the following:
Media Vision PAS16
Sound Blaster 16
ESS 688F Edison Gold
Too many to list.
Lots of great ISA sound card out there.
Reply 14 of 17, by RetroBus
Finally got an Audigy last week, someone listed a couple of computers on facebook marketplace for 20 bucks, I noticed on of them had the Audigy front panel and got in contact straight away! Allways wanted a soundblaster with the front panel and finally, my day has come!
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 15 of 17, by chinny22
RetroBus wrote on 2025-10-06, 10:50:
I have a love/hate relation with Creative front panels.
Hate the extra cabling. Love the look, even if I don't really use it all that often.
$20 is very good deal, even 20 years ago!
Reply 16 of 17, by RetroBus
yeah the cable management is all over the shop in that era, its another IDE wide cable in the box with all of the other IDE cables in there airflow get challenging!
Reply 17 of 17, by Jo22
Back in the late 80s/early 90s there was the art of folding ribbon cables, I remember.
The "masters" or "gurus" of PC building had the talent and knowledge to fold cables in a clean and tidy way. 😉
Unfortunately, once fold, the cables never became straight again after that..
Edit: Others did slice their ribbon cables, I remember.
So one wide ribbon cable was turned into a few stripes of smaller ribbon cables, basically.
It was the home made alternative to round IDE cables.
That was in a time of 40 conductor cables, of course.
Zip ties further helped to improve cable managment.
