First post, by iiamsiincere
Hello
I'm going crazy trying to figure this out, so any help would be appreciated. I'm using Win 7 Pro and I'm trying to install the video drivers to my Radeon HD 4870. "Technically" the drivers install but every time I try to install it, it quickly get's to the driver's installed screen but is yellow indicating there were errors. When you click on the logs, it says everything was successful. Then I noticed that the Catalyst Center doesn't seem to be installed. I've installed different versions of Catalyst Center from version 11-14. I even found an ISO of a Radeon HD 4850 CD that had the separate CCC installation folder (that I couldn't find anywhere online individually) and that didn't seem to change anything even though it said it installed correctly.
Does anyone know if this is common and how to fix this? Is the only fix to install Catalyst on WinXP in order to get the Catalyst Control Center?
I was hoping to use Win7 in order to use the Windows Media Center features that don't appear in WinXP.
I could also try Win Vista as some youtubers say it's currently a lot more usable then it was back in the Win7 days.
