First post, by douglar
Seems to run fine in 2d windows, but in Dos, the characters look like they were run through a replacement cypher.
The attachment Photo Aug 29 2025, 6 46 50 PM.jpeg is no longer available
It was missing an inductor and I replaced it. Should I redo the inductor or does this look like something else?
The card did crash on me after running quake 2 for 2 minutes.
Reply 1 of 5, by pixel_workbench
That is usually a symptom of memory corruption. Either a bad memory chip or a broken connection to one or more pins on the chip.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 2 of 5, by douglar
pixel_workbench wrote on 2025-08-31, 00:18:
Ooof! That’s a toughy with BGA memory chips.
Reply 3 of 5, by tehsiggi
See the repair thread in my signature. That's very certain a memory issue. You can run R3MEMID to identify the faulty channel and then see if there is something wrong / damaged on the board.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 4 of 5, by douglar
tehsiggi wrote on 2025-08-31, 07:05:
Thanks, you make it look possible
Reply 5 of 5, by tehsiggi
At least the diagnosis is relatively straight forward. That'll give you an idea what you'll need to do in the end. Does the pattern change if you press on any of the memory chips?
