First post, by Guy
Any idea which card can this be? It has Samsung mem. chips and it was made in 2002 that's all I can discern.
Looks somewhat like this one; https://www.reddit.com/r/pcmasterrace/comment … e_4_mx440_64mb/
Also like this one; https://www.vgamuseum.info/images/palcal/nvid … _comlete_hq.jpg
Both are GeForce4 MX 440's. It's a generic pcb design used by multiple companies.
Cool, I have another 440 mx but it looks very different, green pcb larger cooler but it doesn't have a fan.
You can always remove the cooler and see what's written on the chip. That'll be pretty conclusive...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
I did unscrew the fan but it has the heatsink is secured with these annoying white plastic clips thingies that are impossible to remove without breaking them.
If you have a larger ballpoint pen you can unscrew the tip and use that to squeeze together the plastic pins. Also, gently warming up makes plastics a bit more flexible. I don't mean 100s of degrees, rather a bit with a hair dryer..
If you have this card in possesion why not install it in a system and see what the bios message shows.
Why removing fan and heatsink when its not needed.
Robin4 wrote on 2025-09-05, 00:11:If you have this card in possesion why not install it in a system and see what the bios message shows.
I installed it on my P4 it's a mx 440.
