First post, by simon_e_hall
After a couple of beers and watching YouTube and in need of a new project, came across lots of videos of people creating some rather cool 'home labs', but fully aware I do not have the space, budget or interest in modern stuff like AI.
But I did have a bit of an odd ball idea, I have an SBC dual P3 on a passive backplane not doing much work.
file.php?id=189316
I do not have a rack, but can clear a space in a book shelf.
So my plan:
1. Clear a shelf in the bookshelf next to my desk
2. Install some sort of shelf with rails in now empty bookshelf, so can pull out and have easy access
3. Get a new passive backplane, maybe one with a bridge chip so I can have multiple PCI and ISA slots
4. Install that on shelf
5. Get and install random unusual PCI and ISA cards I see out in the wild now and then (but never use to get and then regret not getting them) and then enjoy, tinker, play, e.g. saw a HF/VHF Ham radio card once for cheap, but never got that and have regretted that ever since
So, anyone tried doing this before (had a quick look but saw nothing, maybe because it is a stupid idea) or have suggestions for unusual PCI and ISA cards to try if I can find them?
Reply 1 of 15, by chinny22
If it works for you then it's not crazy!
I remember someone here used the motherboard tray from an old case to mount his setup under a desk.
It was for somewhere "strange" like kitchen or garage which was why they didn't want a stranded case and the setup did make sense.
Few others have made cases out of cardboard boxes or wood (and made them look good) So I say go for it!
Reply 2 of 15, by simon_e_hall
Well, proof of concept and extendable shelf installed in the bookcase, with space to spare on top.
Decided to leave a nice amount of room on the bottom for 2.25" drive bays and construct some sort of drive tray below, should be enough space to fit 6 x 5.25" bays in along with the frame to support it, for the removable storage side of life.
Got a new backplane on the way, with approx. 14 slots (ISA/PCI), which should fit on the shelf, when that arrives will move the power supply and 'front panel' around.
On the home lab side of life:
Compute side is sorted with the SBC, it has Windows Server 2000 in RAID (4 x 8GB Disk on Modules on a dedicated card) already setup, so can just (famous last words) transplant that to the new backplane.
Storage side, thinking of getting another RAID card, maybe with more than 4 slots (maybe 8? Then RAID it again), and doing what I did with Windows 2000 and installing Disk on Modules into it, so it is compact and efficient.
Network/Router side, will look at that later once the backplane and main setup are fully working, but should be easy enough to get multi port network cards
Lab side of life, not too sure yet, radio over TCP/IP, video, have a few ideas looking at the cards gathering dust in my collection, or a mixture of everything I can think of.
Reply 3 of 15, by dionb
Not too crazy at all. My only concern would be buildup of dust over time. I've contemplated something similar myself - putting motherboards in drawers just high enough to fit the cards in. Unfortunately I never found the ideal set of drawers so I abandoned that idea.
I've seen even more eccentric things. This GA-7IXE board and attached peripherals hung on the wall was for several years the home server of a friend of mine:
The attachment servertje.jpg is no longer available
Reply 4 of 15, by simon_e_hall
dionb wrote on 2025-09-04, 13:43:
That setup is rather out there, I like it!
Dust is a concern on my mind, I was thinking when everything is in some sort of Perspex/acrylic cover, and maybe some fans with filters in the future.
Reply 5 of 15, by simon_e_hall
The idea grows arms and legs:
1. 2nd WiFi card installed, so the 1st network card connects to the normal home network, the 2nd card allows access for older WiFi cards such as Aironet 350 which does not accept modern encryption methods and cannot connect to the home network.
The original plan was to be able to use WiFi in my NT 3.51 laptop which is still used but despite the Aironet 350 driver .INF file stating NT 3.51 Support, I cannot get it to work with, so back to plugging in the cable to access the home NAS.
2. 8 port raid card, just waiting on the drives then will setup the server further
3. Terminal services all setup and now can configure the server remotely, no need to keep plugging in the mouse, keyboard, monitor, etc...
4. Removed the 3dfx card, as it will go to waste here, plus gives me back a PCI slot
5. Have a digital I/O card installed for playing around with various things
The power supply in the photo is for testing purposes only, the backplane is all screwed in, there is still a lot of bits to do, such as attach rails to prevent the PCI/ISA cards from moving around and give them some support, cabling, front panel, etc. And, not even started on the drive bay area yet.
Reply 6 of 15, by megatog615
I like this idea!
I have once considered getting an industrial SBC with onboard NIC and alternative power connector(like molex), taping off the PICMG edge connector and mounting it in an existing home server. Could even build an internal serial null modem cable to connect to the server's main motherboard if both had a serial header.
Reply 7 of 15, by bracecomputerlab
I own 1 Tektronix TLA7012 portable mainframe and 1 TLA7016 benchtop mainframe where I live.
I also own 2 TLA7S16 serial analyzer modules (for PCI Express Gen 1 / 2)and 6 TLA7AA4 (2 of them are 450 MHz state speed models) as well.
I have one P6810 general purpose probe and a PCIe x16 interposer card to be used in conjunction with 2 TLA7S16s.
I will say that I own serious lab level equipment.
Reply 8 of 15, by simon_e_hall
bracecomputerlab wrote on 2025-09-10, 09:10:
I own 1 Tektronix TLA7012 portable mainframe and 1 TLA7016 benchtop mainframe where I live. I also own 2 TLA7S16 serial analyzer […]
damn, rather envious, but does give me an idea, pretty sure the digital I/O card I have had some software for voltage probes, etc. No idea where the kit and software are though. Not much movement on the bookcase retro home lab though, just sorting out fittings and connections at the moment. Also with any project, the solid state RAID has decided to die, so fault finding that.
Reply 9 of 15, by simon_e_hall
Well this has been a nightmare recently, but some glimmers of joy. I had the operating system install on a 3Ware 3W-6410, (4 x 8Gb modules in RAID 10) and it has worked without problem for months up to this point. However, I knocked one of the power cables which stopped one of the modules, no problem I thought, RAID 10 can re-build. But no, Windows 2000 kept failing saying boot device error, so after lots of moving things around, still could not get it to boot.
In the end decided to just do a reinstall, which kept failing with Windows saying 'it cannot save the configuration data' (despite the additional drivers for the 3Ware card being installed at setup), now I have installed it before on this card with this configuration with no issue at all previously, nothing has changed. One thing I did notice which is odd, that after a reboot of the failed installation, either one or two of the modules would be marked 'Out of use', again whatever I tried Windows refused to install on the RAID (and seemed that the Windows drivers mucked it up).
So, gave up on the RAID and installed Windows to a CF Card, then installed the RAID drivers, and everything seems to be working perfectly, so at some point I will move the operating system off the CF Card back onto the RAID, but for the time being it can stay on the CF Card as that has wasted so much time.
Now to good news, for ages I wanted to set up a GPS timed NTP server, I saw articles about it years ago and had all the parts but never ever got round to it, or had an appropriate setup, so Pentium 3 bookshelf home lab, is doing its first real home lab stuff and receiving timings from GPS and setup as an NTP server!
Reply 10 of 15, by simon_e_hall
Things are taking shape:
Two TP-Link TL-WN851N cards (1 for access to the home internet, 1 ad hoc to allow older none WPA2 devices to attach
One 3ware 3W-6410 RAID card, (4 x 8gb modules in RAID 10) for the operating system (maybe)
One Adaptec AHA-2940U2W SCSI, for attaching a SCSI tape drive for backups, and maybe more
One 3ware 7506-8 RAID 10, with 8 x 8gb modules for storage (not decided on how I am going to configure them yet, i.e. 2 arrays or 1 big array
Next steps:
Still to get multi port LAN card for the ability to connect older none WiFi devices to
Need to find a suitable PCI riser card, as the 7506-8 when populated with the 8gb modules, blocks access to a PCI slot, so need to move it slightly
Sort out the ISA side of life
Construct what is going to house the drives below the shelf.
Reply 11 of 15, by wierd_w
I am doing something even more excessive, after scoring two 20u racks for free from work.
Maybe I should start a thread, even though it's not vintage gear exactly.
Reply 12 of 15, by simon_e_hall
Made a start on the removable storage bays, went for a slightly odd drive selection:
50-Pin SCSI - wanted IDE (for compatibility) but the IDE drives I have are worn out and have issues
Ultra2-LVD/SE Tape drive
GoTek Floppy (wanted to use a proper 1.44mb and 1.2mb drives but they are in my 486 build)
IDE ZIP 100 (because I always wanted one running)
USB Multi card hub (USB port and various card types for assisting with vintage builds)
PCMCIA (as I like using these with old laptops and now makes data transfer between them easier) via ISA card
Hardware wise:
Got a 2nd dual port network card, wanted a quad port card, but had issues with them.
have PCI riser to move a RAID card to allow the dual port network card space, but now need to secure that
Issues I have had recently,
Getting the 3ware RAID controllers to play nice was a pain, it makes the RAID array number, based on the 1st disk in the set used, so originally each controller had an array 0, as I used the first disk on each controller to build the RAID (thought that would be fine on two different controllers) but this caused conflicts. So now have one controller with an array starting at disk 0, and the 2nd controller the arrays start with disk 1 (then each odd number disk) and disk 2 (then each even number disk). Also every time I used RAID 10 it would randomly put a drive out of use and had rebuild issues, so all drives are now RAID 5 with a hot spare and things are working. Anyone had issues with 3ware before?
Future:
Have a Advantech PCL-731 card, 48 port logic card, plan to set that up to control the children's playset I have built near my desk, e.g. control a crane, lights, etc. Plan being to introduce them to simple programming/electronics. So the PCI will be dedicated to storage and networking and the ISA side for industrial control.
Reply 13 of 15, by simon_e_hall
wierd_w wrote on 2025-09-23, 15:28:
Nice!
Reply 14 of 15, by wierd_w
I should start a new thread for my own homelab project...
But, I am now the owner of 2 netapp DS2246 SAS disk shelves, full of 900gb SAS disks.
I get paid again next week, and will source a 10gbit managed ethernet switch that does LAPC link aggregation for bonded iSCSI, and appropriate HBAs+cables for my new-to-me shelves.
I'd post pics, but the room is bathed in 'suspicious purple glow' from my indoor tomato plants.
Ok, I made my own thread. 😁
I'm building a homelab...
Reply 15 of 15, by simon_e_hall
Been a while, but things as ever do not go smoothly.
So while trying to get Active Directory going, Windows 2000 refused to put that on the CF Cards as they are removable storage, makes sense and I expected issues there. So I went to do a clean install on the RAIDs as they seem to be worker happier, so that is the time the CD Drive died, typical! So need a new CD drive.
So did an improvised plan B and found a copy of the Hitachi Microdrive filter driver (as a test as the driver is for XP), changed the driver of the CF cards from standard disk to the Hitachi one and now Windows 2000 sees the CF Cards as fixed disks, and Active Directory installed with no issues.
Sad as think this project is nearing the end of its current evolution, tested the 48 port digital logic card and that is working which is the next part, unless I find some unusual ISA cards to install, but IRQ's are getting thin on the ground now.
One area I need to think about which is bugging me in the back of my mind is cooling, power and CPU are fine not too happy with the air flow though and of course cable management.
