First post, by wierd_w
Ok, It's rude of me to hijack somebody else's thread, so here is one of my own instead.
About two weeks ago, I scored a pair of what looks like 30 or 40U 4 post racks for free, after we upgraded the in-house cable system.
The attachment 2025-09-19-12-11-35-626.jpg is no longer available
They have an antedeluvian 12 channel analog cable TV system installed, that can accept what looks like analog composite inputs, and then encode and combine them for a local cable tv system. I dont need that, but maybe someday I'll play with it.
Just not today.
I took my dirty, used shelves home and put them in my 'for projects' room, which happens to also be where I am growing some indoor tomatoes. (Which is why images of this room are bathed in purple glow. The DEA will be sorely disappointed.)
The attachment 2025-09-20-12-10-32-569.jpg is no longer available
For completeness and to avoid the inevitable commentary, yes, really. Tomatoes.
The attachment 2025-09-26-17-27-57-644.jpg is no longer available
Yesterday, I got 2 Netapp DS2246 SAS shelves (full of 900gb sas disks) delivered and installed in the racks.
The attachment 2025-09-28-19-20-13-872.jpg is no longer available
These shelves need a special cable, but are otherwise just dumb SAS shelves that can work with a generic SAS HBA in a linux box, which is how I intend to do this build.
I have centered the shelves with 4U of space between them, so I can put the head unit (after I build it) in that space, then have primary array shelves on the top part of the rack going up, and mirror array shelves on the bottom going down, in a nice orderly manner.
Reply 1 of 18, by wierd_w
The racks came with air blower fan modules, and master power cutoff modules, along with some absurdly long power strips.
The fan blowers are fully contaminated with some very nasty, gritty feeling dust, so getting those cleaned, or better, refurbished with Noctua fans, is gonna be another, different subproject. On the plus side, they appear to be standard sized fans, and I strongly suspect I could bolt liquid cooling radiators onto them for use in the second rack...
Which will become home to some virtual server heads... 😁
I am able to get domestic fiber here, so this should be a fun little project, once I have it all assembled.
Reply 2 of 18, by SScorpio
My big concern would be noise and power which translate into both heat and hit to your wallet. 48 <1TB drives is still under 43TB of usable storage. It's across a lot of drives so you'll have great throughput, but three 14TB drives will give you the same amount of space. Throw in a fourth and you can have a parity drive.
Enterprise servers are another issue. They are designed for blow through cooling with no concern for noise. Prepare for the sound of a jet engine readying for takeoff.
If you want to tinker and explore, go for it. But I would advice against a 24/7 setup unless it's in the winter when you need heating.
I'm not sure what type of fiber you can get. But Pentium Gold 8505 mini PCs with two SPF+ that can handle up to 10Gb networking are ~$300 and the SOC only uses 15W. Total draw can will very greatly due to whatever SPF devices you end up with. But that's enough power to route, run a media stack, and host normal services.
Reply 3 of 18, by wierd_w
I'm a trained SAN guy, I know the sound.
I *also* know that I can slowly transition this shelf from spinny disk to commodity m.2 flash modules, which use a fraction of the power, and produce much less heat.
The caddies and shelf are agnostic to what disk type is in there, as long as it is sff sas.
So, things like this can go in the caddies.
https://www.amazon.se/-/en/BeMatik-NVMe-SFF-8 … r/dp/B07RMHH4GW
The project room is permitted to be noisy. The tomatoes wont care.
Mostly, I couldnt beat the price for second hand shelves with storage. Many sales wanted vastly more for empty shelves, without disk caddies, and with obscene shipping.
I got 2 shelves FULL OF DISKS, and very well packaged, for 600$ WITH shipping.
Again, I am aware that I dont *need* to fill these with spinny disks. There *are* options to go full flash. I can just hit the ground running cheaply this way, and hold on to the spinny disks for 'thrashy' applications and spares for same, later.
If I go full flash later, i'd bulk buy the adapters from aliexpress.
Reply 4 of 18, by SScorpio
Sounds like you know what you're getting into. Some people would see all the empty space on the racks and get a bunch of "cheap" servers. Then get shocked when their monthly power bill is more than they spent on the hardware.
Reply 5 of 18, by wierd_w
No. I intend to put a home made linux head in an aftermarket 4U rackmount chasis, that's designed for liquid cooling.
Perhaps not this one, but similar.
https://www.amazon.com/RackChoice-rackmount-C … /dp/B0BXJ5HF2W/
While I do in fact know how to administer a old FAS series netapp filer head, there is ZERO compelling reason for me to do so.
That case supports a front facing liquid cooling radiator, and can accept server boards, and commodity psu's. It shouldnt break the bank to run.
The disk shelves are where the hunger will be, and again, a road to all flash exists.
Reply 6 of 18, by simon_e_hall
Wow, that is some space to play with
Reply 7 of 18, by wierd_w
Indeed. When the prospect of saving them frim the dump came up, I jumped on it.
While hardly fasionable home decor, there's a lot of fun you can put in a rack.
Reply 8 of 18, by wierd_w
Re: Flash Later, agnostic shelf
The thing that's hard to get without getting scalped are the caddies.
(Seriously. Look at this awful price. I got a FULL SHELF FULL OF DISKS, for 300, with shipping! This is JUST the caddies!)
OUCHIE! My wallet!
This is why I bought 'with disks' and did not care about their capacity.
Aa for the caddies themselves...
I pulled a caddie and took it outside for better photography.
These are nice HGST brand drives, and not shitty seagate garbage, so I got a steal in terms of spinny disk, imo.
However, you can see that these are just normal SFF SAS, in every way.
The shelf does not care.
The attachment 2025-09-29-17-37-34-131.jpg is no longer available
The attachment 2025-09-29-17-37-45-478.jpg is no longer available
This is why the SFF flash adapters can just go right in.
(Insider info: I used to be a Netapp support rep for FAS series filers. While the drive pictured is netapp branded, due to it's model number nomenclature, it's actually a bog standard HGST drive in every physical way, with a blessed netapp firmware. This firmware is enforced by Netapp filer heads, not the disk shelves. A dirty secret is that the R&D people buy the correct model generic disk, and just write their blessed firmware on it with hgst's firmware updater. Another dirty secret is that you can turn off enforcement of blessed firmware in those filers. I dont care, since I wont be using a netapp filer. The shelf just talks ordinary SAS, and just reports drive identity info as it gets it. No policing. You can put any old SFF SAS disk in there. The only caveat, and a pretty big one, is that the adapter you drop in must not be SFF-8639 direct NVME passthrough. You need one that can supply the correct signalling. These DO exist. The connector design for SAS disks is meant to be back compatible, in that older drives should be connectable to the newer port. So, to have the correct signalling for this shelf, you need an M.2 adapter that has "B-Key" msata support. (Like this ugly thing). msata B key is slower, but also cheaper, so meh. )
Reply 9 of 18, by chinny22
Nice Rack, great looking pair
...I'll stop now.
Seriously though, still dream of getting a full sized rack for the garage to set up my servers and Comm's gear properly.
And free/cheap second hand units are becoming rare with companies downsizing physical hardware for quite a while now.
I was also going to say $600 for the lot is good price as caddies by themself are never cheap, but you already covered that!
Will this be data storage for the whole house or just for you projects? If it's the latter then no need to run 24/7 anyway
Reply 10 of 18, by wierd_w
Yup.
I too held off on this kind of thing, because shipping big racks like that would be prohibitively expensive. Fate just dealt me a once in a lifetime opportunity, and I scarfed it down.
Ultimately, I want to use this as a storage appliance to host some virtual game servers for some side channel income. (Thus, the research into using commodity flash devices instead of using power hungry spinny disks).
I will probably leave a few of them in the shelf for use as swap space LUNs for said virtual servers (Swap on flash is not wise, and I want to avoid having compressed swap in ram), since some of the stand alone server daemons out there ONLY run on windows (and windows gets BigMad if it does not have swap)
I want to plan ahead for reducing the utility bill in advance. Thus, all the research into inexpensive flash in the shelf.
These shelves have IOM6 controllers in them, and those support SATA transport over SAS, so the MSATA M.2 adapters to SFF SAS should work without quibble.
(The much faster NVME to SAS adapters use a much newer transport that my shelves dont speak. I'd need newer shelves. These shelves were second hand for a reason, and I'm not gonna cry in my beer over that. MSATA adapters are fine.)
I get paid again next Wednesday. I'll go shopping for a 10gbit switch that does LAPC then.
Reply 11 of 18, by wierd_w
It's been a few months.
Prices in everything have exploded.
progress still (slowly) continues.
I was recently re-gifted an old 5th generation i5 wih 8gb DDR3 ram, (and my vintage aptiva case!) From the nurse friend I built it for nearly a decade ago.
I hope it still works after what I found when disassembling it...
The attachment 2026-02-15-15-05-01-411.jpg is no longer available
The CPU cooler has inhaled some very nasty stuff. I hope it hasn't been silently roasting underneath. 🙁
The attachment 2026-02-15-15-11-28-911.jpg is no longer available
I disassembled and cleaned everything, applied new thermal compound, and placed it inside the new 4U rosewill rackmount case. I threw a completely inappropriate testbench PSU in, because it's what I have on hand.
The attachment 2026-02-15-15-02-47-736.jpg is no longer available
The attachment 2026-02-15-16-03-48-870.jpg is no longer available
It fits perfectly in the 4U space I left between the disk shelves! Lots of space on either side, to stick more shelves in later, if I want/need to!
The attachment 2026-02-15-16-28-54-700.jpg is no longer available
A Dell gigabit switch that supports channel bonding was put in the topmost 1U, just above the mains breaker.
Reply 12 of 18, by tomcattech
chinny22 wrote on 2025-10-04, 04:37:
...I'll stop now.
🤣... Speaking of... My wife would lose her crap if she walked into my office and saw\heard that running.
Hell, she hates it when I use the heat gun (noise)
(She'd be OK with the tomatoes)
Keep us updated!
I either fix it or break it permanently... there is no try.
Reply 13 of 18, by wierd_w
The benefits of being single, and not looking! 😁
Reply 14 of 18, by wierd_w
My fancy SAS cables arrived today.
They seem to be working, since the linux live USB can see the SAS controller, enumerates SCSI devices (sgx devices), and then assigns them scsi disk IDs (sdx devices)
The attachment 2026-02-22-12-59-03-137.jpg is no longer available
The attachment 2026-02-22-12-58-26-456.jpg is no longer available
Looks like these netapp shelves have disks that are still formatted with 520 byte sectors, and I need to reformat them to be 512 byte instead. This is completely doable, it'll just take a long assed time.
I found my switch is missing one of its cooling fan assemblies. It blows the existing fan very hard and flashes an amber warning at me about the missing cooler, but does power on and work. I see I can get the missing cooler from fleabay for entirely too much money, but if I want to do this right, I need it.
The disk shelves initially spin up their fans like an industrial blower, then settle into a 'less loud' drone. It's not intolerable, but yea, is a bit loud.
I am doing the initial linux install today. I'll source a UPS to put on before I attempt the scsi disk reformat. I *DO NOT* want mayhem and murphy's law to visit while that is cooking.
*other* things to do include crawling under the house to run a cat6 cable from the utility room to the projects room, and attaching keystone boxes on either end. At the moment, I am 'using' a powerline ethernet setup to get 'connectivity' in there. It's enough to get internet for install/update, and to setup and use SSH to get the ball rolling, but I'll want to have gigabit in there. (Not 'maybe kinda-sorta 100Mbit')
I also should consider more (ancient) memory. 8gb is 'not sufficient'.
I AM pleased that the cleaned cooler is holding steady in the 40C ballpark, and that the cpu did NOT roast to death.
Reply 15 of 18, by SScorpio
wierd_w wrote on 2026-02-22, 18:48:
In the grand scheme of things, the cable itself is cheap. Never run just one when you've opened walls. Get at least two, and even think about running a fiber line. Pre-terminated cables are surprisingly affordable. And you can easily step up your link speed by upgrading SFP+ modules.
Reply 16 of 18, by wierd_w
My difficulties compound.
I think this motherboard is indeed actually failed in some insidious way. I should get out a magnifying glass and inspect it closely some other time.
It start having data corruption on the SATA interface after about 40 minutes of operation, regardless of what drive is connected. Further, the NVMe slot does not seem to operate correctly. I have in fact swapped all the cables with known good ones.
Rather than dick around with it too much, and since I have ram and a CPU on hand, I instead elected to get a compatible one off Fleabay for cheap.
I'll investigate further when it arrives.
Reply 17 of 18, by wierd_w
The 'new' board came.
it has a damaged ram socket (per memtest results) : It's an Asus ROG Maximus Hero VII.
Took some poking in the bios to get the nvme slot to turn on.
Works otherwise, and doesn't spontaneously trash the ATA bus after a few minutes like my prodigal child was, so it is now in service. Took my old CPU and RAM just fine, aside from the damaged slot.
Linux finally installed.
Got an actually appropriate 650W supply, and a 500gb NVMe SSD from a local mom&pop, and dropped them in.
Snagged a 1tb sata spinny disk (that's CMR!) From the stack of lost souls at work. Put a swap partition and 2 ext4 partitions on, as /etc/apt/cache and /var, respectively. That should take most write hits except during a system update, and can host the deduplicator's hash table/logfiles without trashing the primary storage for the filehead.
Did a test run on a few of the 520/sec disks to reformat them, and was successful. I can actually see blank disk when querying them now.
Built a quick and dirty shellscript to fire off all the remaining disk format operations in parallel, and left it to run before coming to work today.
Completion status was 20% by the time I got out the door.
I'll cook up the md groups tonight.
Reply 18 of 18, by wierd_w
My disks all reformatted successfully. I now see an enormous number of ~800gb disks in gparted, and can actually do stuff with them.
The attachment 2026-03-04-16-27-50-446.jpg is no longer available
Since the list is not sanely sorted, I'll do the following:
Power comletely down.
disconnect the bottom shelf.
Configure an md device pool using the top shelf disks.
power down
disconnect the top shelf, connect the bottom shelf.
create an identical disk pool with the bottom shelf disks
power down
connect both shelves
make an md pool from these two pools, as mirror.
I should have about 20TB of raided and mirrored storage to do whatever with after that.
