First post, by ejphanzol
Hi retro enthusiasts,
I'm the owner of the following system:
-Gigabyte GA-5AA motherboard rev 3.2
-Chipset ALI Aladdin V @ 100 MHz
-AMD K6-2 @ 550MHz
-Noname sd -> ide adapter
-Asus Voodoo 3 3000 AGP
-128MB PC133 @ 100MHz
-Crystal ISA soundcard
The thing is, i think it is underperforming. There are more threads about this topic, but not with the normal K6-2. I hope there are more owners of this motherboard, to compare the results of some benchmarks.
1: Speedsys
Memory bandwith: 352 MB/s
Vesa memory: 83525 MB/s
CPU score: 631.00
Data cache L1 (32KB) 2505.92 MB/s
Data cache L2 (512KB) 317.38 MB/s
Memory Throughput 172.87 MB/s
2: 3dMark99 640x480 tripple buffer (16 bit colors)
2304 3DMarks
6715 CPU 3DMarks
3: Final reality Default settings No sound
3.35 Reality marks
4: 3DMark 2000 640x480 tripple buffer (16 bit colors)
1247 3DMarks
Anyone experiencing the same results?
Reply 1 of 3, by Disruptor
Operating System?
Size of external cache?
It may be likely that just 64 of your 128 MB SDRAM are inside the cacheable area of your external cache.
Reply 2 of 3, by ejphanzol
Disruptor wrote on Yesterday, 21:05:
Operating System?
Operating system is windows 98se.
The size of the external cache is 512KB.
I will try 64MB RAM.
Reply 3 of 3, by Disruptor
You also can try this tool from heise's famous c't magacine to measure cacheable area:
https://ftp.heise.de/pub/ct/ctsi/ctcm17a.zip
