First post, by SGM
I have a good Socket-7 motherboard for a ~1997 project, but it has a few severely bent pins. Is it possible to straighten them without snapping them off? What are my options here? I couldn't find any YT videos either.
The attachment pins.JPG is no longer available
The attachment pins2.JPG is no longer available
Pentium MMX 200 (at 166MHz), 64Mb, 2Gb (CF), AWE32, S3 Virge DX/GX, 14" CRT, Win95.
Pentium 3 at 700MHz, 384Mb, 16Gb (CF), AWE64, Radeon 9200, white 15" LCD, Win98SE.
Toshiba 320CDS: Pentium MMX 233, 32Mb, 2Gb (CF), slow LCD, Win95.
Reply 1 of 4, by tehsiggi
If they've only been bent once, you can just bend them into their original position again.
If they snap off, you can (gently) lift the black plastic frame on the bottom up to remove it (given that all other pins are straightened).
Then you can desolder those defective pins and solder in some new ones. You can just buy a pinheader and remove the pins from there for your repair.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 2 of 4, by dionb
For that gentle bending, I find a medium-sized crosshead/Philips screwdriver is generally best.
Reply 3 of 4, by DaveDDS
If bending them back, I'd just move them a bit - wait a bit for internal structure to settle, then move a bit more & repeat,
rarely this can make a difference ... (but you have to be extra careful as it makes for more times you can screw it up)
I use a super-fine set of needle-nose pliers for such things. I also have some different sized "machine screw" socket pins
which can help a lot (depends on how fine the pins are)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 4 of 4, by NeoG_
I'd use needle nose pliers on that
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6800, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
