First post, by Dude111
Hello dues Im wondering if some of you might know whats causing this?
Notice the menu DOES NOT FIT THE APPLET and the 3 check boxs are not boxs!
http://img1.pixhost.to/images/10277/662574889_capture.png
If I bootup in safe mode every menu displays right so its gonna be a driver I assume Since safe mode uses different drivers.....
The first time this happend I simply deleted "shelliconcache" and it fixed itself but not this time.......
This is Win98se and everything in device manager says all stuff is working OK so it must be a driver file but I dont know which one!!
Thanx guys 😀
