First post, by Sphere478
I have been looking for one of these cards since I think probably like 2005 and I finally found one. I’m really curious if it ends up being faster than a radeon 7500. Or radeon 9250
Stay tuned. 😀 I’m gonna find out on my all pci /isa systems. 😀
In the meantime post your thoughts and expectations
Also, think I might be able to flash it to a fire gl of some type?
Sphere's PCB projects.
Reply 1 of 21, by douglar
I never tested a radeon 9100, but I had difficulties getting either a PCI radeon 7500 or a 9250 to work reliably with my K6-III board, probably because I was using the AT Power connectors P8 & P9, so it was potentially a 3.3V power issue.
I'd say my best "non-geforce" PCI benchmark scores came from a PCI Voodoo 3 with SGRAM, although my PCI Banshee pulled a head by a bit in 3dMark 99. Maybe 3dMark 99 weights single-texturing higher than multi texturing?
Here are my benchmarks--
download/file.php?id=229021&mode=view
The 9100 should perform pretty close to the 8500le, yes? It should do pretty well. About 2 months ago, I tested my K6-III with an AGP Radeon 8500 and it did quite well.
Here are some other fish to look for--
  • I have in my notes that ATI made a Radeon 9650 PCI. That's quite the white whale. Might be "apple only", but maybe it could be flashed to PC? Or get one of the PCI-e versions and put it in an adapter?
  • Visiontek made a Radeon X1300PRO & X1550 PCI. That's easier to find if you are willing to move to XP.
  • The AGP-PCI bridged Matrox G450 card I got was disappointing. Not worth hunting for unless you just want to double check my results.
Reply 2 of 21, by douglar
I’d add that while the 9100 should do pretty well, it probably needs a faster cpu to make much of a difference. A 2gh P4 was entry level gaming when that gpu came out. With a K6-3, it might be a bit slower than a 3dfx or a geforce mx card just because the driver was optimized for a system with more cpu.
Reply 3 of 21, by BitWrangler
douglar wrote on 2026-01-08, 18:25:
I may have heard whispers of a 9550 PCI but not a 9650, as well it doesn't seem to fit the budget card numbering used at the time.
Reply 4 of 21, by gonzo
douglar wrote on 2026-01-10, 12:23:
Exactly what I mean, too.
I LOVE CPUs RUNNING IN [GonzoHz]
Reply 5 of 21, by douglar
BitWrangler wrote on 2026-01-10, 14:41:
There may have been a PCI version of this card---
https://theretroweb.com/expansioncards/s/unknown-radeon-9650
Reply 6 of 21, by BitWrangler
That's a 9600 though, says so on it, no idea why it would be titled as 9650
Edit: likewise the apple land 9650s come back as 9600 Pros when you compare the board image. Some Apple or 3rd party nonsense that 9650 designation not an ATI one.
By the way I was trying to dig out possible 9550 PCI and came across this on Deb's site (anyone seen her lately?)
https://www.gpuzoo.com/Compare/ATI_Radeon_925 … TI_Radeon_9550/
Which would seem to imply there was little point in a 9550 PCI when it was about level with a 9250 PCI in AGP form, except the memory, and I don't tend to see good/fast/wide memory going on PCI versions of cards, so it probably would have got the same handicap as 9250 PCI. So 9250 PCI might be as good as it gets in that timeframe.
Reply 7 of 21, by douglar
BitWrangler wrote on 2026-01-10, 15:19:
Hard to say. I’ll see what I can find out. I suspect the card has the r351 110nm die shrink of the 9600 chip.
I could be mistaken about the whole pci 9650 thing. I found in my notes an annotation that I saw an oem 9650 pci when making this list last summer. http://www.vogonswiki.com/index.php/ATI#R300 Sometimes work requires that I stay up late at night and I just start scanning through lists of video cards to stay awake. I take notes, but my recollection of all the cards I looked at isn’t always so clear the next day. So it could have been a typo. I didn’t record a pcb number.
Reply 8 of 21, by gonzo
@ Sphere478: just an idea how to make the test (the comparision) more easy - you can use an AGP-VGA instead of an PCI-model. They are lots of Super-Socket-7-mainboards having an AGP-slot, and the Radeon 9100 AGP was by far much more on the market compared to the PCI-version. The same applies for the AGP-versions of the Geforce -VGAs compared to their PCI-models.
By the way - a Radeon 9800 AGP (having a 3,3 Volt-key for the AGP-voltage) can be used with a Super-Socket-7-system, too. Of course, like all other AGP-VGAs onto a socket-7-board with AGP, this 9800 will run at a maximum of AGP 2x-speed.
Reply 9 of 21, by Ozzuneoj
douglar wrote on 2026-01-10, 15:11:
The label seems to pretty clearly say 9600, even if it is smudged a bit.
That's a 9600 though, says so on it, no idea why it would be titled as 9650 […]
I have one of these Apple 109-a58503-20 cards and I just pulled the heatsink off to see what it says. It says 9600 Pro on the die. Also, I used digital calipers and measured the die at ~8.86x8.86mm with is roughly the same as the 76mm^2 reported for the RV350 ... for what that's worth.
The attachment 20260112_125636.jpg is no longer available
This particular card doesn't have the extra pins for the Apple Display power (pretty sure that's what they are for), but I have not tried it on a PC yet. I have a feeling it will show up as a 9600 Pro though if it works.
It seems that in Apple land, specificity of hardware specs and naming is\was not normally a thing. It'd basically be a "Radeon Ninety-six-whatever.... mid range model." So, it could be a 9650, 9600, Pro, XT, whatever and so few people cared or bothered to dig into it any further that there are effectively no records about the hardware online... you find the same card listed as all of those things (some with or without the extra pins) and as far as I can tell, not a single die shot of any of them to confirm what it is. I found one discussion here, but again, no one seems to have cared enough to document any more than what is said there.
On the other hand, in the land of PCs it is recognized that there is a pretty substantial difference between a "9600" and a "9600 XT", and the existence of a 9650 at all would warrant serious discussion among enthusiasts and collectors (see this thread as proof, 🤣 ).
All that said, a Radeon 9500\9600 series of any kind in PCI would be pretty interesting, though the bottleneck gets significant at that point and if it ended up being a 64bit card like a 9600SE or 9550, it may or may not actually be faster than the 9100 in all situations. I personally find the 9100 interesting because it was the last time anyone bothered sticking a flagship GPU of any generation on a PCI card (even if R200 was previous gen when the 9100 came out).
(More pics of the Apple card.)
The attachment 20260112_142346 (Custom).jpg is no longer available
The attachment 20260112_142401 (Custom).jpg is no longer available
The attachment 20260112_142427 (Custom).jpg is no longer available
Reply 10 of 21, by douglar
Yours sure looks like an rv350.
Here’s the pics collected so far—-
https://theretroweb.com/chips?chipManufacture … ge=24&name=9600
There was an rv351
https://www.techpowerup.com/1036/rv351-info
I have a mac 9600xt at home that looks a little different 109-A58503-20 vs 109-A13600-10
https://theretroweb.com/expansioncards/s/ati- … n-9600xt-mac-g5
Mean while… when do we get to see the radeon 9100 benchmarks?
Reply 11 of 21, by Sphere478
I never tested a radeon 9100, but I had difficulties getting either a PCI radeon 7500 or a 9250 to work reliably with my K6-III […]
X1300 pci I have. It posts but drivers dont work.
I think I found some obscure x300/x500 something based pci card that was like a firefl or workstation thing. Tried it, couldn’t get it working. And the video connectors were terrible also. So no go.
7000,8000,9000 seem to be the series cards that work the best.
A 9650 pci is very intriguing
I have a parhelia, it is about on par with a 7000/7500 if I recall
G450 is nice, but nothing special
I have ran a 9800pro in k6-3 and cyrix mii systems. It made a difference. There is still performance on the table it seems above 9250
gonzo wrote on 2026-01-12, 16:59:
I have other builds for the agp stuff. This is trying to find the fastest for my pci only socket 7 builds
douglar wrote on 2026-01-13, 00:53:
Card arrived today. Computer however is in storage rofl. And there are some other priorities. So not any time soon 🤣.
But in theory, eventually.
I should be able to post better pics of it in the next week.
Its at my friends house and I think he may have a cyrix computer we might be able to bench it in. Will see if that’s possible. But my retro collection is currently in disarray because of moving activities haha.
Reply 12 of 21, by dm-
the worst thing about radeon cards - they does not like to work on non/standard agp/pci bus freq.
this is why i prefer to stay with geforce pci cards.
btw r350 has same pinout like 9250 chips. one day i'll do the chip swap on some random radeon 9250 pci, but really not soon.
Reply 13 of 21, by tehsiggi
dm- wrote on 2026-01-13, 05:56:
It has the same ball arrangement, but not the same pinout.
RV250 (Radeon 9200 & 9250)
The attachment Screenshot 2026-01-13 at 11.05.46.png is no longer available
RV350 (Radeon 9600)
The attachment Screenshot 2026-01-13 at 11.05.58.png is no longer available
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 14 of 21, by NeoG_
From the testing I've seen they also have the highest overhead which is a thing on a CPU limited platform like SS7
Reply 15 of 21, by Sphere478
Not going to have any time to play with this for a while probably. Lmk if anyone sees any damage.
Excited! 😆
Hope to break some personal pci-only socket 7 records!
Reply 16 of 21, by Repo Man11
Assuming that you'll be testing it on something like a TXP4 I'll be curious to see how it compares to this.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 17 of 21, by Sphere478
Not sure, but maybe one or both of these.
tyan s1564 or epox mvp4 when I get around to it.
The mvp4 is a pci only and can do a high FSB
The tyan will be 66mhz fsb only.
MVP4 socket 7 aiming for the stars!
Reply 18 of 21, by gonzo
Sphere478 wrote on 2026-01-15, 06:03:
Not sure, but maybe one or both of these. tyan s1564 or epox mvp4 when I get around to it. […]
My favorite is the ASUS P55T2P4 in the latest Version of it. This is for me the absolutely best No-AGP-board with socket 7 in AT-format. It has undocumented options for a Vcore down to 2,0 V; a FSB of 83 MHz can be adjusted (undocumented, = 500 MHz K6-III+ for example); it works with ALL socket-7-CPUs; it can handle K6-2+/III+ and HDDs up to 120 GB with the latest Patch-BIOS from 2002; and it is rock stable in performance. Using a second TAG-RAM, it can adopt at least 256 MB (4x 64 MB) EDO-RAM (maybe even 512 MB, but I am not sure, as I do not have such RAM-modules).
On the other hand, VIA-chipset-boards (having MVP-chipset) are known for a poor RAM-performance compared to Intel-chipsets, so they are not appropriate for best scoring (even they are stable in performance, too).
Reply 19 of 21, by douglar
Ozzuneoj wrote on 2026-01-12, 19:35:
I tool the heat sink off my Apple Radeon 9600xt and it had an R360 chip-- https://theretroweb.com/chips/4165
Looking at your chip-- The part number ends with an "11F" instead of a "13F". That suggests to me that you might have the 110nm die shrink R351, not the 130nm R360. But I also see chips that end 12f and 11fl, so I don't really know.
The attachment Untitled.png is no longer available
Edit I took a look at a radeon 9550 and it was also 8.9mm on a side, so that looks the same
The attachment Radeon 9550.jpg is no longer available
