First post, by balthazor4ever
I just bought a biostar 8433 uuc motherboard . It is a revision 3.1 with a removable ODIN RTC. Of course its battery is dead. The motherboard has the pads for a classic barrel battery. If I solder one or the adapter for a coin cell battery (I have both from previous projects) would it work and keep the settings or should I try to replace the ODIN RTC?
