First post, by ENunn
i'm trying to figure out if i'm able to install windows 98se on my optiplex 755. it's got a core 2 quad and a 7900gs. the only reason why is that i want to run a game for a video i'm thinking of and i don't want to deal with a virtual machine. and it's the only retro pc i have.
i don't know where to start. my cd drives don't work and i would like to install 98 from a usb. if i can get 98 working and booting i do want to dualboot xp. what should i do here? any tips?
the
Reply 1 of 4, by cyclone3d
It will work with 98. There should be a modified chipset driver to use. Use NUSB for the USB storage driver. Use the Microsoft 2004 update CD to update Windows 98. It is available on vogonsdrivers.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 4, by ENunn
thanks. i assume the drivers are all on vogonsdrivers? does anyone have a step by step tutorial on how to get it all working?
i tried installing it via win98-quickinstall. i got it booting but it's so unstable. every time i reboot i get this bsod:
keyboard doesn't work so i have to hard reboot. but i can eventually get in.
i got the tweaked 82.69 nvidia drivers installed, but opening up the settings tab in the display properties crashes windows. right clicking the desktop crashes after that.
widows isn't booting up at all now. it shows the splash screen for a minute and then my pc shuts off.
is it because i have 1gb ram installed? i don't have another ram stick to try.
the
Reply 3 of 4, by cyclone3d
Possibly. You may need to slipstream in the R.Loew memory patch.
It can be gotten here: https://www.philscomputerlab.com/rudolph-r-loew-patches.html
Archive.org also has it.
YMF7x4 Guide
Reply 4 of 4, by ENunn
i tried to install patchmem before windows broke and it said something along the lines of "xxx file found without backup - skipping, no changes made"
the
