First post, by visiblyshak3n
Hi Everyone,
I just recently purchased a MT-32 (Old version, no phones in the back) along with a Behringer Eurorack mixer to use with my Mister fpga setup for primarily DOS gaming as well as other devices like the X68k. I used to use a MT32-pi for a while with my Mister, but figured I'd finally grab the real deal since I enjoy the sounds so much.
Testing with Ultima VI or Monkey Island 1, it sounds amazing, but certain games have some issues and I can't seem to pinpoint exactly what it could be stemming from.
For example, both Leisure Suit Larry 2 and Zeliard have booming sound, higher then what I have the volume is set at. But as soon as I adjust the volume knob slightly, it'll go back to the level it should be at if that makes sense. Every time there is a scene change in those games, the same thing happens. Although, not DOS related, Castlevania for X68K sounds strange, like its not mixed properly. Bass sounds up front and leads in the back kinda.
I've been searching and searching online, troubleshooting, but I'm just lost at this point. I've tried performing a reset (R + Master Volume, then 1) but nothing. Something I noticed, was when I initiated the test (3 + MV + V, then power on), I would get a "MIDI error", even though I had both MIDI ports patched in.
I'm not much of an audio expert, but I've setup everything like so:
-The Roland UM-ONEmkII to a USB slot of the Mister, then a MIDI connector labeled "connect to IN" to the IN slot on the back of the MT32.
-A y-split cable connecting the L and R ports in the back of the MT32 over to a single channel on the mixer
-A single 3.5 mm cable connecting the back of my monitor (for HDMI sound, non-MT32 sounds) to a y-split TRS, connected to two separate channels.
-My head phones are patched into the phones port in the mixer to hear.
I have it set to UART-USB mode in the emulator. So once all three devices are on, I just start a game that's been presetup for MT32 and it works.
My only thoughts is that I replace the cables in the L and R ports of the MT32 with separate TRS cables going to two separate channels instead of the Y-split to 1 channel. I know I wrote a wall here, but if anyone of you guys have a moment, I'd really appreciate your insight on my problem.
Reply 1 of 7, by konc
Why does this sound more like a potentiometer issue to me? I'd try some contact spray.
Reply 2 of 7, by NeoG_
If my understanding is correct, you basically can't prevent games from sending a master volume sysex command that changes the MT-32s volume to override whatever you have set on the front panel. As soon as you adjust the volume from the front panel it uses your setting until another sysex command overrides it again.
Reply 3 of 7, by SuperDeadite
Regarding X68000 Castlevania, it's meant for the "new type" MT-32 family. To my knowledge there are no X68K games meant for the old type, but there is very little data on this topic even in Japanese.
Also, are you on real hardware or emulation? If real hardware, which MIDI board do you have? The old Sacom board with the full size din5 plugs are known to have issues with some games.
Edit, you are using a MiSTER and UART cable. Castlevania loads a ton of custom instruments via Sysex. X68K does not use "intelligent mode", but if sysex isn't transmitted perfectly, weird things will happen. I also have little data on the state of MIDI board emulation in the MiSTER core, but it was still a work in progress last I checked...
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 4 of 7, by Falcosoft
Neog is right. The master volume of the MT-32 is software controllable by Midi/SysEx messages. A game can change the master volume either by sending explicit volume change messages or implicitly by sending a reset message. Reset messages implicitly set the master volume to default 100%.
So you should set your gear in a way that it sounds good with master volume set to 100% and you should not rely on manually setting the master volume to get good sound. If you want to change volume you should alter mixer volume etc. instead.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 5 of 7, by visiblyshak3n
SuperDeadite wrote on 2026-05-07, 09:53:
I'm on real hardware with the the "old" MT32 I believe. Firmware shows it's 2.00.
As far as I know, MIDI with Mister is in a working state and has been for a while now. For both hardware and emulation. I used to have a MT32-pi connected before to the Mister, but that was connected via a short datalink usb cable to the port on the side of the mister with output through plugging my headphones to the back of my monitor that the Mister's hdmi cable was plugged into. No mixer was needed. There were no issues outside of some scratchy sounds rarely. This was with games like Ultima VI, Zeliard, Castlevania X68K as well as others.
Aside from the Roland UART cable, there is also this device available for connecting to mister https://www.legacypixels.com/mister/midi.html. The difference being that it uses the Mister's datalink port as opposed to just a regular usb port with the UART cable.
Falcosoft and NeoG, what you guys have described with the SysEx messages changing the master volume is exactly what's happening in my situation (at least for Zeliard and Leisure Suit Larry 2). I'll just have to adjust my setup to make it less painful to my ears so it's not a big problem when it happens.
As for Castlevania sounding badly mixed, I have two separate TRS to TRS cables coming tomorrow and I'll patching the L and R ports on the back of the MT32 to two separate channels on my mixer instead of just 1 balanced channel. The thing with Castlevania is, it sounds like the instruments are being loaded, it's just not mixed properly so I'm hoping that the cables will fix that but again, I'm no expert.
Reply 6 of 7, by NeoG_
I experienced it with some sierra games forcing master volume 100 and some forcing master volume 80. In my situation I can control the mixer levels for the MT-32 audio inside a batch script so I do that to compensate for the volume change. I just leave everything at default on MT-32 (via MUNT) and adjust it that way. But given you are using an external mixer that won't be an available option for you.
Reply 7 of 7, by visiblyshak3n
Just wanted to follow up here on this thread to let you guys know I've finally fixed the issues with my MT32.
With the odd sounding Castlevania X68k, I mentioned I would get two TRS to TRS cables and plug them into the L and R jacks on the back of the MT32 and into 2 separate channels onto my mixer. Before it was a Y-splitter cable on the back into 1 balanced channel.
Well, after doing that, the problem went away and it now sounds great so it was just a wiring issue. There is some random distortion here and there and I'm sure thats because the game is for "new" MT32 like SuperDeadite mentioned (Konami intro or death jingle for example, play super fast.)
As for the SysEx commands increasing my volume for certain games like Leisure Suit Larry 2, I did what was recommended and left the volume knob alone and only adjusted the master volume on my mixer. Works great and I've been able to play it now with no problem.
Thanks for the help guys.
