MattRocks wrote on 2026-06-03, 14:47:Cheers, that's useful. […]
The Serpent Rider wrote on 2026-06-03, 12:39:
Regular GeForce 256 can't monitor RPM. ASUS V6600/V6800 Deluxe probably can.
I don't believe nVidia or any AIB included pointless pins for laughs. Given my LRI board has no dedicated hardware monitoring IC yet definitely expects three pin fans, my best guess is the PCB routes the tach signal to the headers on the PCB to be read in a factory (testing, debugging, production validation, supplier acceptance, system-builder testing, etc.) I don't feel like putting any electrons through the board to find out though.
The ASUS Deluxe boards give us a hint of what those factory debugging instruments could do.
There are three options for temperature control.
- Fully external.
- An external control circuit using a thermaldiode built into the chip.
- An internal circuit (located entirely within the CPU/GPU/etc.), integrated into the die.
The thermodiode was first introduced in the Radeon 9 series and the FX 5 series.
However, the vast majority of graphics cards were not equipped with the monitoring chip itself (lower-end FX models did not even have the necessary pads for it), which is required to read data from this thermodiode.
What’s more, the Radeon X has a monitoring chip (connected to the built-in thermodiode) with an RPM-reading function and a three-pin fan. However, the fan’s RPM pin isn’t connected to anything.
And measuring the fan speed without knowing the measured temperature is completely pointless.
PS. As far as I can remember, there were GeForce 2 series cards with a monitoring chip, but the sensor was soldered onto a flexible ‘tab’ that was pressed against the bottom of the heatsink.
off-topic/ However, modern graphics cards have come a long way.
If a blue screen of death appears on an RTX graphics card, it could be ... because the backlight connector had come loose. 😀 or 🙁
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
