First post, by zwrr
Hello everyone, a friend gave me a Matrox G400 graphics card. He told me that the card cannot be used. I checked and found that an R50 resistor on the card was damaged and an A8 component fell off. It may have been caused by an impact. The R50 resistor measured 93 ohms. It may be a 100 ohm resistor. I looked up the information on the A8 component and found that it may be an LDO voltage regulator. There is AE text on the component. What specifications of components can I use to replace and repair it?
The attachment G400-1.jpg is no longer available
The attachment G400-2.jpg is no longer available
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
