First post, by zwrr
- Member
A friend gave me a non-functional SC-55 MK II. Upon inspection, I found the issue was simply a faulty power supply; it worked perfectly after I replaced it. However, I noticed three flying wires on the motherboard. The adhesive securing these wires is the same type used to secure the capacitors, so I suspect this was done by the manufacturer. The unit runs on the early version 1.00 ROM. I am very curious about the function of these three jumper wires—has anyone else encountered an SC-55 MK II with similar wiring?
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
