First post, by NorsteinB
Hi!
I was a bit disappointed with my Geforce FX 5200 PCI (128 MB, 64 bit) that is still the second fastest PCI graphics cards I own, next to a CM3 ATI Radeon 9000 256 MB 128 bit that sadly lacks support for 8bit paletted textures, table fog and DX9, with the former two being legacy features often used in W9x games and the latter necessary for some Glide wrappers, so if the FX 5200 was 128 bit, it would tick all the boxes (together with EMBM that the Radeon also supports) and be as fast or even a bit faster than the Radeon.
Then I saw Bits und Bolts upgrading the memory of a Geforce 4 MX 440 SE from 64 bit to 128 bit. He even had to jump through some extra hoops because the only memory he had on hand had twice the capacity so he had to make them be recognized as only half that. No idea why someone would do that to an AGP stinker when the 128 bit version is readily available for around 15 bucks but still.
https://youtu.be/ywnIQXl-Mvs
And so I checked: my Zotac Nvidia Geforce FX 5200 PCI 128 MB 64 bit uses the exact same PCB as the 256 MB 128 bit version, and all the resistors around the back of the GPU look the same. It auto detects the memory so I would "only" need to populate the vacant RAM solder masks and their surrounding resistor pads.
The attachment Zotac Geforce FX 5200 128 MB PCI.jpeg is no longer available
And what's more, I kinda pulled the jackpot with a very late chip from 2008, this is a die shrunk GPU and a later stepping, practically guaranteed to run 300-325 MHz instead of 250!
The attachment Zotac Geforce FX 5200 128 MB PCI front.jpg is no longer available
That got me thinking: why bother with 5ns memory, then? Shouldn't the card handle 4 or even 3ns memory instead, as long as the memory chips that are already on there got replaced, too? People do it for 3dfx cards all the time. And with this FX 5200 having the potential to become more or less the ultimate Windows 9x PCI graphics card, it would definitely be worth the hassle. I even have a donor card here, the Medion ATI Radeon 9600 TX (a 9500 Pro with TSOP memory and slightly higher base clock) with 3.6 ns memory!
I believe at one point I even had a Radeon 9600 XT 256 MB with TSOP 3.3ns memory but I gave that one to a friend in Italy.
So anyway, where is the error in my thought process?
And if there is none, should I keep searching for a 256 MB TSOP2 RAM donor card first?
Reply 1 of 3, by tehsiggi
Having faster memory chips does not guarantee higher clocks. Termination and layout play a large role as well. If the layout sucks or the DDR signals are not terminated properly, you'll have a hard time going faster than the current clock. Team red cards usually need parallel termination on the signals for anything significantly higher than ~220MHz (your 9600TX for example has parallel termination with VTT in place, the Radeon 9000 non-pro does not, the pro does.
I'd even question if the PCI variant of this card would significantly benefit from the additional clocks. Doubling the bandwidth by going to 128bit is more substantial here.
I'd just go for same speed memory and fully populate it.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 2 of 3, by FullYes
If you have the ability to do it I don’t see the harm in giving it a go. To me that is your biggest issue.
For any ram upgrades just be sure the pinouts, voltages and ram configuration is the same
Having that extra bandwidth does make a big difference, I bought a very similar agp fx5200 back in 2003 and it was so slow I ended up selling it and going back to my mx440 until I could afford something faster. The stock FX5200 is so slow, unless you plan on using it in something really not suited for it, you should see an uplift in performance. If you are going to run it in a socket 7 you will really need a k6-2+/3 or 3+ as there is more driver overhead in the fx series vs earlier drivers for say the 2/4 mx pci series or TNT, voodoo 3 etc
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
Reply 3 of 3, by tehsiggi
FullYes wrote on Today, 06:00:
Good point. Whatever memory you use: VDDQ and VDD must match your cards current voltage OR you will have to adjust it. By the looks of the card there is only one linear regulator for the memory. The switching one is for the GPU. The Winbond Chips you currently use have VDDQ = VDD = 2.5V.
The attachment Screenshot 2026-10-07 at 09.00.44.png is no longer available
So you either have to find memory with the exact same arrangement (VDDQ = VDD = 2.5V) or you'll have to adjust the voltage regulation for memory to increase / decrease the voltage. But you'll be probably stuck with VDDQ = VDD since the PCB does not allow for split rails here. The memory used on the 9600TX from Medion/MSI is Samsung K4D261638E-TC36 - it'll run at VDDQ = VDD = 2.5V.
