First post, by Plombo
I have two sound cards in my retro computer: a Sound Blaster Live! CT4780 and a Yamaha YMF724. I can pass the Yamaha's output into the Live by connecting it to the Live's line-in jack, but I'd prefer to send the Yamaha's digital S/PDIF output to one of the Live's S/PDIF inputs. And that's where things get interesting.
After doing a lot of testing today, I've concluded that my SBLive CT4780's S/PDIF inputs only accept 44.1 KHz input, and don't produce any sound when connected to the 48 KHz signal from the Yamaha card. This seems like a rather silly design decision, since the Live internally resamples everything to 48 KHz, but the fact remains that it plays back audio from my CD drive, but not from the Yamaha card. (If anyone's interested, I can provide the details of how I reached this conclusion.)
So this leaves me with a couple of questions:
  • Is there a driver setting somewhere that can configure the Live to accept 48 KHz input over S/PDIF? I haven't found one, but it would be very convenient if one exists and I just missed it.
  • Could I solve this problem by upgrading to an Audigy 2 ZS? I found this from 21 years ago, where someone successfully connected the (presumably 48 KHz) S/PDIF output of a Live to the S/PDIF input of an Audigy 2 ZS. Can anyone here confirm that the Audigy 2 ZS can take 48 KHz S/PDIF input?
Reply 1 of 11, by ott
Plombo wrote on 2026-10-09, 02:15:
I'm interested) Have you tested the YMF724's SPDIF 48kHz output on other devices?
I have Audigy 2 ZS, but I never really thought about the S/PDIF samplerates.
As far as I recall, 44.1/48/96 kHz S/PDIF inputs are supported, but I'll double-check that.
However, if you are targeting Windows 9x and VxD drivers, the Audigy 2 ZS is not the best choice.
Audigy 2ZS VXD driver has limited capabilities compared to WDM driver (no S/PDIF inputs).
For an upgrade, I would choose the Audigy 2 (non-ZS), since it has full VxD driver.
Reply 2 of 11, by Plombo
ott wrote on 2026-10-09, 07:59:
Yeah, what I did was send the S/PDIF output from the YMF724 and the CD drive through a coax->optical converter, and from there to the optical input of the RetroTink 4K CE. In that setup, both devices work and play audio like they're supposed to. The RetroTink 4K also has an info screen that identifies the sampling rate of the incoming audio signal, which is how I found out that the YMF724's output is 48 KHz.
I then recreated that exact setup, but with the devices connected to the S/PDIF inputs of the Live - both the CD_SPDIF header and AUD_EXT pins 15/16. For both of those headers, the 44.1 KHz CD drive plays audio while the 48 KHz YMF724 is completely silent.
I didn't know that! I'm indeed targeting Win9x and VXD drivers. Thanks for letting me know, and saving me from that nasty surprise.
For a while, I was worried that all Audigy 2 non-ZS cards seemed to be missing either the front panel audio connector (which I'm also hoping to use at some point) or the SPDIF_IO/AD_EXT pins. But it seems there are some with both; they're just harder to find than similarly capable ZS cards.
Thanks! I appreciate it.
Reply 3 of 11, by Fazeshift
I would also check voltage levels of the S/PDIF signal. I vaguely remember running into this issue trying utilize the S/PDIF input header on my SB Live. IIRC, the S/PDIF input on the SB Live expects a 5V TTL signal, which was the voltage level on most optical drives. If the Yamaha card output is intended for coax S/PDIF, then the signal is about 0.5Vp-p. The optical convertor might be a little more universal on input voltage level, which could explain why it works via RetroTink in your test.
Just something to consider while troubleshooting.
Reply 4 of 11, by Plombo
That's a great point. I hadn't considered that the voltages could be different. I'm not an expert in circuits or measuring voltages, but I got a multimeter and took some measurements across the ground and non-ground wires.
CD player connected to optical converter: 1.65 V
CD player connected to Live: .621 V
YMF724 connected to Live: 0.0 V
YMF724 connected to optical converter: 0.0 V
I don't really get how it can measure 0 volts in the YMF724-to-converter setup, while that setup is functioning properly. I'm probably measuring something wrong. Or maybe I just don't know how circuits work. In any case, those voltages are definitely different, so that's a second difference between the signals.
I guess the natural follow-up question is: if the Live doesn't, can the Audigy 2 accept coax level signals on its S/PDIF inputs? Or does the entire Live/Audigy line require 5V TTL?
Reply 5 of 11, by jmarsh
Don't connect a CD drive to a device expecting coax SPDIF - as explained it's a much higher voltage and is likely to kill it the converter.
A DC multimeter won't really tell you anything because these are high frequency digital signals.
Reply 6 of 11, by Plombo
I got an Audigy 2 (non-ZS) so I could find out. After a quick test of its S/PDIF input, it seems to be the same as the Live, accepting the input from the CD drive but not from the YMF724. At this point, I suspect the cause is voltage rather than sample rate.
So it looks like my best bet is to find a way to convert the Yamaha's coax S/PDIF signal into a TTL one that the Live/Audigy cards will accept. Some leads I've found on doing that, in decreasing order of how convenient they would be:
  1. Use an RS422 to TTL converter like this one. I've seen RS422 mentioned in the context of S/PDIF, but I still don't understand what their relationship is. Is "RS422 S/PDIF" just a balanced version of coaxial S/PDIF?
  2. This converter. On the plus side, it seems to do exactly what I want. On the minus side, it seems very confusing to use, and requires the extra effort of soldering. And given the cost of shipping from France to the US these days, it would probably end up costing me $100 or something.
  3. DIY approach with a capacitor and voltage divider, as described in passing here. I don't have any confidence in my ability to design or build this. The linked post is also talking about going in the opposite direction (TTL output to coaxial input), so I don't know if it could even be adapted to go in the opposite direction.
So, before I spend any more time or money on this, I have two questions:
  • Can the first approach in that list be made to work?
  • Can someone else with a YMF724 card confirm that its S/PDIF output is 0.5Vp-p or thereabouts? None of this will have any value if the entire theory of the cause is wrong. (I don't have the knowledge or equipment needed to confirm it for myself.)
Reply 7 of 11, by Joseph_Joestar
With a LiveDrive (or Audigy equivalent) it's very easy to get SPDIF from other devices. The front panel has both coaxial and optical SPDIF inputs, and I've had good success with hooking up a bunch of things there. Everything worked fine, ranging from other sound cards to PlayStation and Xbox consoles.
At one point, I had connected the optical output of this YMF744 to the optical input of the Audigy's front panel, and it worked without any problems. I will say, the cards were in different PCs at the time, and I just used that setup for audio recording purposes. But I'm guessing it should also work if both cards are in the same system.
My retro stuff
Reply 8 of 11, by ott
Plombo wrote on 2026-10-28, 03:15:
Congratulations, that’s a great find!
Live/Audigy's CD_SPDIF header is universal input for connecting S/PDIF - it accepts both CD/DVD-ROM's TTL and Coax RCA levels.
I had no issues connecting X-Fi Drive SB0251 and Vortex 2 SQ2500 (both have RCA S/PDIF out) to this input on the Audigy 2 ZS card.
The attachment spdif-rca-audigy2zs.jpg is no longer available
I don't have much knowledge either, but judging by the fact that the second card refuses S/PDIF from YMF724 the issue might lie with the Yamaha itself.
If its 24.576 MHz oscillator is faulty, it could be generating incorrect samplerate instead of the expected 48 kHz (like 48.9 kHz).
In theory, this could be measured by using an analog recording @48 kHz on a second PC or handy recorder, since the digital and analog domains are clocked from the same oscillator.
If the duration of the reference track on the recording differs by more than 1%, then the problem definitely lies with the oscillator.
Reply 9 of 11, by jmarsh
Sample rate from SPDIF comes from the signal itself (i.e. it carries both the data and the clock), it wouldn't matter if it was significantly out-of-spec.
Reply 10 of 11, by Plombo
Joseph_Joestar wrote on 2026-10-28, 03:42:
I'm sure the actual drive would indeed work, but I have a couple of reasons for not going that route. The less fundamental reasons are aesthetic: the color wouldn't match the front of my case, and I don't want to run a cable from the back to the front of the computer. But the main problem is that this computer's case doesn't have a free 5.25" bay. So that's why I'm trying to reproduce the drive's functionality instead of just using the real thing.
ott wrote on 2026-10-29, 16:03:
That's super interesting! Thanks for testing all that!
I think I'll try using the optical/coax converter in the opposite direction, converting an optical source to coax and sending that to the Live/Audigy S/PDIF inputs. That should provide an opportunity to test your findings by removing the Yamaha card from the equation.
And now that I have both a Live and Audigy card, I can also try routing them into each other to make sure that they work with 48 KHz input.
I'm trying to understand how this would work. If the card gets audio from the OS at 48 KHz but tries to play it back at a miscalibrated 48.9, there would be audible errors as it constantly overruns its input buffer. Can a miscalibrated oscillator make Windows actually send audio faster?
I don't think I understand how to set this test up. Do I play a 48 KHz WAV file on the computer to the Yamaha card, and record the Yamaha's output with an audio interface? If that's all it is, I do have the equipment needed to do that.
Unfortunately, I'm away from home for the next week, so it'll be at least that long before I can try any of these tests.
Reply 11 of 11, by Plombo
So I actually got this working. Remember this?
Turns out I should have made that test a bit less quick, and done it as thoroughly as the test with the Live in my first post. It turns out that while the YMF724 doesn't work with the S/PDIF input on the Audigy 2's drive connector, it actually does work with the "CD Digital" S/PDIF input! Meanwhile, the S/PDIF input on the drive connector can take the actual digital output from the CD drive.
In the end, I never learned for sure what caused any of this. But at least it works now.
