GODS - config error
First post, by seanNZ
Im using dosbox 0.65 to run Gods 1.0
Whenever i try to run gods.exe i get a error:
"Error in config file - run INSTALL to configure GODS"
in install.exe i have..
Resolution: Colour vga (theres also ega and tandy colour)
Sound: PC internal speaker
Control: Keyboard
Install Path: C:\GODS
op system = windows 2000
any help?
Reply 1 of 5, by eL_PuSHeR
Yes, edit INI file manually. For sound, you can replace the speaker line with Sound Blaster or Roland.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by seanNZ
I don;t see anything to edit....
GODS.ini :
Sound Blaster
Colour VGA
Keyboard
Version 1.0
072
080
075
077
057
Reply 3 of 5, by eL_PuSHeR
It's already set for Sound Blaster. Try changing IRQ and using low cycles.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
So you start the game from C:\GODS?
Is the gods.ini file there, and not readable/hidden or something?
Reply 5 of 5, by eL_PuSHeR
It works perfectly fine for me using DOSBox 0.65
Check what WD said...
Normal Core and 10.000 cycles. SB voices in intro + Music. Rest of the game is AdLib sound effects only.
Intel i7 5960X
8 GB DDR4 (2100)
