First post, by Jiri
Return of the Phantom by MicroProse Software works fine in DOSBox 0.65 (with speech) but the CD version install still gives the error: "The game needs 0 bytes of disk space. You only have 0 bytes available". So here is a temporally solution (until it is solved in DOSBox) for installing the game:
1) copy PHANTOM and RESOURCE folders from the CD to your mounted C drive
2) copy attached files CONFIG.PHA and INSTALL.EXE to PHANTOM folder
3) run the game with PHANTOM.BAT in PHANTOM folder - you can play without the CD in the drive and change the game settings with INSTALL.EXE
    PHANTOM.zip
    50.03 KiB
    973 downloads
Reply 3 of 6, by Shagittarius
Just won a copy of this off ebay, the message exactly is:
"The game needs 0 bytes of disk space. You only have 0 bytes available."
Which sounds to me like it should work =).
Hope I didn't necro this thread, thought you might still be wondering since its still happening with ver .73.
Reply 6 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Same issue as reported in another thread, where there is a workaround for MicroProse installers that have the "need 0 bytes" problem, and not just for the game mentioned in this thread.
