First post, by ftballer57
ok i played the game fine for a while but then i saved my game and went to sleep came back later and tried to start the game up again but everytime i run fall.exe z.cfg i get illegal call 7..........can anyone help me?
Reply 1 of 12, by ftballer57
what i do is
mount c c:\dagger
fall.exe z.cfg
i acts like its gonna work but then it just says illegal call 7 and closes dosbox...could this be a problem with my save game? if so how do i run fixsave without the cd....oh and another thing what should someone with a 1.7ghz proccessor and 1 gig or ram set their cpu cycles and frameskip at to play Daggerfall? any help will be great!
Reply 4 of 12, by wd
Rank DOSBox Author
DOSBox Author
In the start menu for dosbox you should find a DOSox.conf
There are several items that you can modify, search for the
core=normal one and change it to core=dynamic or core=full
and test the game again.
Reply 6 of 12, by ftballer57
i changed it to full and it doesnt close by itself but it just stays at a black screen and the status window says
read from port 8ee8, len 1
read from port b6e8, len 1
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
First, put all mount commands (cdrom if available, and the emulated
harddisk) into the autoexec-section of dosbox. Should look like
[autoexec]
mount c c:\games
mount d f:\ -t cdrom
when c:\games is a directory on your harddisk that contains the dos games,
and will be the place you install new games to.
Then reinstall daggerfall, and try again.
