First post, by Xelasarg
- Member
I know this isn't an officially supported version, but I'm completely lost and maybe someone has found a simple workaround (I guess there are some ppc users out there).
I've got the following problem:
I'm running n0p's DOSBox port (based on v0.63) and it randomly (and quite often) crashes AD&D rpg's when reading/writing to disk. I've experienced this with Pools of Darkness, Secret of the Silver Blades and Death Knights of Krynn so far. The crash occurs either when loading the fight screen or when saving the game. It just exits from DOSBox back to the today screen. The taskbar is gone, and I have to start DOSBox again and exit it manually to bring the taskbar back 😖
I've tried it on both a WM2003SE (XDA III) and a WM5 pocket pc (MDA Vario II).
Thanks for your help!
-Alex
"What's a paladin?!"
