First post, by preludebabe
I have followed all the instructions for loading a game on dosbox (at the moment I am trying to put on either discworld or discworld 2) It has mounted but everytime I put in the file command to run the game - it says unable to change to and the filename. I have followed the instructions on BAT files and exe files. I have to be going wrong somewhere. Please help. Im not computer minded but I love these games (more playablity then these new fandangled games).
Your help is greatly appreciated.
Thank you.
Reply 2 of 8, by preludebabe
I set up a new directory as DOSbox and new one as oldgames, I placed the discworld info inside old games. Then I loaded on DOSbox and followed the instructions to mount the c:\oldgames. As far as i can see it mounted, Then when i type in cd discwolrd or dsc or dwb - it says it cannot find the file? I did try c:\discworld\folder1\folder2 but still nothing.
I hope i have done this right. I do have SCUMM but that doesnt like me at all on any games including simon the sorcerer.
Reply 3 of 8, by eL_PuSHeR
Rank Moderator
Moderator
I think you made a mess of the mounted drives. You need BOTH a CD drive (where you install game from) and a HARD DRIVE to install to:
E.g.
mount d f:\ -t cdrom
This is for the cd part. Change f for the real letter of your CD/DVD drive as shown inside My PC.
mount c c:\oldgames
Then you go the CD drive and invoke the game installer (common names install, setup, etc). After installing it, go to C: drive to start playing it (you may need to leave cd in drive as well).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 8, by preludebabe
OK - have mounted the cd drive as D D:\ t- cdrom. Everything was successful. Until that is getting the game to run on it. I have made sure that the file name is correct and that it is in old games, that i have the correct direct X to play these games. They are exe files on my disc (this is the original game as i bought it new years ago) so I know everything is right. Any help would be fantastic.
Reply 8 of 8, by MiniMax
Rank Moderator
Moderator
Sound in DiscWorld?? Try looking here:
Discworld 1, config problem
It can be made to work.
_________________
