First post, by Darkcraft
I want to play swiv 3d and I hav al legal copy of the game. I installed it and started it but it didn't start. I went to dosbox and mounted the cd an my hd started it an i get no cd found!?
WELCOME TO THE FORUM, Darkcraft.
You probably forgot to mount the CD drive. Write down here all commands you used.
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Uuuhm lets see.
HD = D:\
Disk = E:\
I did this:
Cd in the player. Installed Swiv 3d for DOS. Launch DOSbox. Mount my HD http://i191.photobucket.com/albums/z41/Darkaquarium/Knip […]
Cd in the player.
Launch DOSbox.
Mount my HD
Then added my disk
Then i typed these codes :
d:
dir
cd swiv
swiv_dos.exeThen it will start and shows me SCI (makers of the game) and then suddenly it crashes an says this :
Try this:
Launch DOSbox.
Cd in the player.
Mount my HD
Installed Swiv 3d for DOS from inside DOSBox.
_________________
nope. still the same error.... 😵
Maybe cuz I am running Vista??
have you tried:
-label "swiv 3d"
-ioctl ?
Water flows down the stream
i will try now + the tips gave before. hope for the best...
still won't work... 🤣 😖
CD is seen by Windows as a music CD. Maybe this can help.
Try it with a cdimage (cue/bin pair created by isobuster or something).
ok i'll try 😁
nope didn't work....
How did you mount the image?
I mount the image with powerISO. in a virtual drive
See about the imgmount command in the dosbox readme, that is don't use virtual cd software.
i do imgmount f D:\SWIV 3D.iso -t iso but it can't find the iso...
You need to put the filename in quotes if it contains spaces:
imgmount F "D:\SWIV 3D.cue" -t iso -label "SWIV 3D"
_________________
it worked it found the iso but the game won't start.... 😵 😵
Maybe the game checks for the audio tracks on startup. An ISO image will not contain any audio tracks. You have to create a BIN/CUE image, and mount the CUE in DOSBox, in order to get CDDA.
I will make a bin ok??
wich code i need to use it gives ceu is unsupported. 😒
