First post, by Pete
Hello!
I installed my old "Civilization", installed DosBox and run this classic in DosBox. Everything works perfect. Except one thing - after trying to save my game "Error writing map file" appears. The game enables you to choose the letter of the drive where the game should be saved - from A: to F: - and it does not work with any.
Does anyone could help me? I would be truly grateful!
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Well, how are your drive letters set up in DOSBox?
_________________
Reply 2 of 3, by `Moe`
Just press Enter when asked for the drive letter, and if that doesn't work, check if the directory or files are set read-only.
Saving works just fine in Civ if everything is normal.
Reply 3 of 3, by Pete
Thanks for such a quick reply!... Most often I mount Civilization directory as C drive. No file, no directory concerning Civilization is set read-only. I still don't know what to do.
