First post, by RaimundP
Hi there,
running DosBox 072, mounting dirs / everything working, lots of games
already running, joystick: ms sidewinder pro (windows xp, joystick
enabled and visible / ok),
Config :
_--------------------------------------------------------
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=auto
cycles=max
#cycles=16186 (tried 6000, 8000, 10000, ...)
cycleup=500
cycledown=20
[joystick]
joysticktype=2axis (tried 4axes, ch, ... )
#timed=true (tried false / true hunded of times)
#autofire=false
#swap34=false
#buttonwrap=true
[autoexec]
# Lines in this section will be run at startup.
mount c H:\DOS\DRIVEC # SYSTEM und CD-Installs
mount d H:\DOS\DRIVED # SPIELE
mount e H:\DOS\DRIVEE # NEUE SOFTWARE
# ----- mount CD-ROM paths -----------------------------------
#mount F K:\ -t cdrom # REAL CDROM
mount F L:\ -t cdrom # VIRTUAL CDROM
#mount F H:\DOS\CDROM\LOLCD -t cdrom # LANDS OF LORE
#mount F H:\DOS\CDROM\WARC2 -t cdrom # WARCRAFT II
#mount F H:\DOS\CDROM\WARC2EXP -t cdrom # WARCRAFT II EXPANSION
# ----- mount HD-FOLDER CD-ROM paths -------------------------
#mount F H:\DOS\CDROM\DGAMES -t cdrom # DEADLY GEAMES
#mount F H:\DOS\CDROM\SYSSHOCK -t cdrom # SYSTEM SHOCK ENHANCED
#mount F H:\DOS\CDROM\SKEEP -t cdrom # STONEKEEP
#mount F H:\DOS\CDROM\SC -t cdrom # STRIKE COMMANDER
#mount F H:\DOS\CDROM\FIST3 -t cdrom # Armored Fist III
#mount F H:\DOS\CDROM\JA -t cdrom # Jagged Alliance CD Full
#mount F H:\DOS\CDROM\TNOVA -t cdrom # Terra Nova
#mount F H:\DOS\CDROM\UNITY -t cdrom # TNG: A Final Unity
#mount F H:\DOS\CDROM\TOS25 -t cdrom # TOS: 25th Anniversarity
# ---------- PATHS ---------------
SET PATH=C:\DOS;Z:\;C:\STINGRAY;C:\QEMM;C:\WINDOWS
SET STINGRAY=C:\STINGRAY\
SET TEMP=C:\TEMP\
SET TMP=C:\TEMP\
cd c:
C:
Oookay: i am owning lots of pcs in all variations (from 2 mhz to XXX,
a small EDV musuem (private) : commodore, Atari, etc. etc) and lot
of dos-gams.
everything working just fine: BUT:
RED BARON
No Joystick at all available, under the menuoptions no joystick
will be selectable...
Strike Commander: (Floppy AND CD Version)
calibrate Joytick every time: left / right still works fine - but up/down
just baaaaaaarely (just barely noticable)
System: on this pc: Athlon 3000+, XP, all new drivers, clean
system (28 tasks running), 2GB, etc
any ideas how to play my favorite dos games RB & SC ?
Ray
