SB PCI128 Installed - No Sound!
First post, by MusicallyInspired
I've got a Sound Blaster PCI128 in an old Pentium 2 400mhz system running Win98. The drivers are installed (after a bit of a hassle with Windows not believing my PCI128 drivers were for this new PCI Multimedia unknown device) but when I go to play sound you can't hear anything. I looked at the volume control and the levels are jumping...just no sound coming out. When you turn the computer on and off the speakers make a noise too so I know my speakers and the card's output are working.
Also when you change the volume levels in the volume control the system framerate slows down tremendously until you let go of the mouse button. Maybe that has something to do with it?
Any help would be nice. I remember this card working perfectly fine before I put it into this machine. I've also since tried an Audigy 2 card and the sound works fine....if I have to I'll try putting the PCI128 in another computer just to verify where the problem actually lies. I hope it just lies with the drivers somehow.....This is the only card I have that works with DOS games. The custom Audigy 2 DOS drivers I found don't work at all.
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
Reply 1 of 28, by Amigaz
Which drivers did you install? filename etc...
Most drivers found on the net are mostly update drivers to existing drivers
Reply 2 of 28, by MusicallyInspired
I have the original CD. I installed from there. I'm trying some from the Creative website now. But I don't think it's going to work.
My Github
Reply 3 of 28, by 5u3
Did you check for resource conflicts? In theory, the SB 128 PCI should support IRQ sharing, but in reality this almost never works, especially on old chipsets.
If your system has ISA slots, consider getting a classic SB 16, it would provide far better DOS game compatibility than any PCI card.
Reply 4 of 28, by MusicallyInspired
Getting another card is out of the question. This is my last DOS-compatible card and I don't have money to spend on others right now.
There are no device conflicts or anything at all. It works there's just no sound that comes out....
Could something be wrong with the output?
My Github
Reply 5 of 28, by MusicallyInspired
Ok, something new I noticed here. Whenever sound is being used the system slows down considerably. It's like the message to play sound goes through and the levels on the volume control jump, but before it gets to the speakers something goes wrong and no sound comes out and the system slows to a crawl until the sound is supposed to have finished (which takes longer than the sound should play).
EDIT: Actually I've just noticed that even though I first installed the drivers and they were fine, after I restart the computer (after the initial installation of the drivers) the "Creative Sound Blaster PCI128 Legacy Device" stops working. The exact message is:
"The CONFIGMG.VXD device loader(s) for this device could not load the device driver."
I don't know what the Legacy Device has to do with the regular device (which is working fine) since that's only for DOS applications. Windows sound should be running fine. It's all very confusing to me...
My Github
Reply 6 of 28, by red_avatar
We're talking about $5 here - that's how cheap a SB16 ISA is. It's less than what you spend on food in one day. PCI 128 is NOT a good soundcard anyway - it emulates MIDI and sounds horrible in a lot of games. For DOS it uses Legacy drivers which
a) suck up loads of conventional memory meaning a lot of games using high amounts of conv memory will refuse to run
b) are a real pain to set up and you can run into many IRQ problems because Windows does weird things with the settings.
Reply 7 of 28, by Amigaz
Agree, the SB128 is crap
Only good for Amiga's with PCI busboards 😁
Reply 9 of 28, by Amigaz
Like I said, I have no money to spend. That means I don't have $5. And I know the PCI128 is crap but it's all I have.
Have you tried any updated drivers from www.creative.com?
Reply 10 of 28, by red_avatar
Sell it then or trade it for the SB16 😉
Reply 11 of 28, by MusicallyInspired
I've tried updated drivers but they don't even install. Says it doesn't detect any Sound Blaster hardware. The ones from the CD seem to be the only ones that will install. Maybe it's toast.
My Github
Reply 12 of 28, by swaaye
photograph the card for us 😀 Or at least get the CT**** number off of it. It might be some weird OEM version.
Also might want to try taking all cards out except it and the video card. And try different PCI slots. Depending on your mobo, the PCI slots will share IRQ signals with each other and some cards do not like to share with others.
Reply 13 of 28, by MusicallyInspired
Actually I've looked and I can't find any CT numbers anyway....very odd. It says Ensoniq at one part and PCi64 on another. But it's a PCI128. I'll have another look and get a picture as well.
My Github
Reply 14 of 28, by MusicallyInspired
Here's the card. On the back there's a sticker that says:
E1427881 AudioPci 9806
ASSYNO: 01 REV E
But no CT**** numbers anywhere. That I can find anyway.
http://brandonblume.commerceculture.co.uk/oth … ures/pci128.jpg
My Github
Reply 15 of 28, by Amigaz
Here's the card. On the back there's a sticker that says: […]
ASSYNO: 01 REV E
That's no SB128 PCI, my friend
looks more like the SB64, it was a very common OEM card
Reply 16 of 28, by MusicallyInspired
Those liars....
Way back my dad bought this from a local computer store (not a chain). First we tried a SB Live, then an Ensoniq, then they gave us this one which they said was a PCI128. The install CD they gave us even says PCI 128 and has PCI 128 drivers....that's what always worked! Amazing.....weird as well since these drivers always used to work before.
Well that's good to know! I'll try PCI64 drivers, then!
My Github
Reply 17 of 28, by 5u3
Looks like an Ensoniq AudioPCI re-branded by Creative.
There is a very nice Wikipedia article about this card (seems to be written by board member swaaye 😀).
Although this is the best PCI card for legacy Sound Blaster compatibility, it still means more hassle than the real thing. But I'll shut up already. 🙄
Reply 18 of 28, by MusicallyInspired
...the best PCI card for legacy Sound Blaster compatibility...
Really? It always sounded horrible to me. But then maybe that's because I was using the wrong drivers the whole time....*shrug*
My Github
Reply 19 of 28, by red_avatar
PCI64 16 and 128 use the same DOS drivers so why would it sound better on the SB64 ? It all sounds wrong - a lot of midi music in games use the wrong instruments.
