Reply 26820 of 52781, by Windows9566
Finally found a IO shield for my Intel Advanced/ML board
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 26822 of 52781, by Windows9566
luckybob wrote:
Those are "standard" ATX shields.
its just the standard that came before THE STANDARD. Think USB 1.0
I thought the standard IO shield was like
PS2------------LPT----------JOYSTICK---
PS2--USB--COM---COM---AUDIO PORTS
Reply 26823 of 52781, by luckybob
The key word I used was BEFORE. The one Windows9566 linked was the very first version. USB killed that version.
You only ever see the first version on early Pentium motherboards (and Pentium Pro).
Reply 26824 of 52781, by Thermalwrong
The new old stock 486 motherboards from Ukraine arrived today 😁
1.82 MiB
The box was a bit ripped but they were well packed and it's weird seeing a 486 motherboard look this new & clean. The one on the left I already have and bought solely to have a read of and digitise the manual, since that's not online in its complete form anywhere.
1.79 MiB
Now to see if I can get PS/2 mouse working on the FIC 486 VIP IO2 board by just adding the headers. I spent all that time trying to fix that Asus PVI-486SP3 board and now a good source of equally capable boards has appeared 😁
Reply 26825 of 52781, by appiah4
Thanks to the kind souls on Vogons who gave me the heads up to the eBay seller selling these blank back plates for real cheap!
Does anyone happen to have the blueprints for an AT backplate? What diameter hole, at what location etc? Also, what do I cut a backplate with? Some Dremel drill pit would do?
Reply 26827 of 52781, by liqmat
appiah4 wrote:
https://i.postimg.cc/Cnz85hkJ/Blank-Back-Plates.jpg https://i.postimg.cc/K4zBJNwL/Terratec-128i-PCI-TTSOLO1-SL-Box.jpg […]
I have a bunch of new AT backplates for the motherboards I have. I could scan one in for you or measure. Let me know.
Reply 26828 of 52781, by appiah4
oeuvre wrote:
use a plasma cutter
I was hoping it would be the same diameter as my lightsaber.
Hey I would definitely appreciate that if you have the time and all.
Reply 26829 of 52781, by PcBytes
Thermalwrong wrote:
The new old stock 486 motherboards from Ukraine arrived today :D […]
That barrel battery in a spot where a CR2032 battery should be is by far the most stupid thing I've seen today.
Who thought that would be an great idea? Especially since these are notorious to leak and kill traces.
Reply 26830 of 52781, by liqmat
appiah4 wrote:
I was hoping it would be the same diameter as my lightsaber. […]
oeuvre wrote:
use a plasma cutter
No worries, this way you could at least print yourself a paper template. I would send you one, but I don't even have enough for my motherboards unfortunately.
Reply 26831 of 52781, by appiah4
No need, punching a hole in these shouldn't be too hard, I just need to know where and how big 😀
Reply 26832 of 52781, by Thermalwrong
At least they're easy to desolder and replace with a regular CR2032 holder 😀
The barrel battery on the MS-4143 is juuuust about to leak, just like my other one - that's getting removed and replaced this evening.
For the ATX to AT backplate, I measured that a couple of weeks ago while making some up from similar blank ATX plates, try these dimensions:
Looking from the back of the case: Going from the edge of the ATX case area, so ignoring the area to hold the backplate in place […]
Going from the edge of the ATX case area, so ignoring the area to hold the backplate in place (but not the raised edge)
Top: 24mm
Bottom: 7mm
Left: 110mm
Right: 33mm
4.48 KiB
Reply 26833 of 52781, by Munx
Congrats on obtaining unobtainium. My P200 Build has been sitting shield-less for years...
EDIT: a quick search for IRDrive on ebay and I found one finally!
My builds!
The Underdog - The budget K6
Reply 26834 of 52781, by liqmat
For what it's worth.
649.1 KiB
Reply 26835 of 52781, by SW-SSG
Oh neat, I was watching the listing for the FIC for a while but ultimately decided against it. Nice to see that it was the real deal...
Reply 26836 of 52781, by appiah4
Much appreciated, thank you.
Reply 26837 of 52781, by GigAHerZ
Just got the Asus P/1-P55T2P4.
It has 256KB of on board cache and has COAST slot for additional 256KB of cache... and i apparently had one of these just laying around from decades ago!
Nice board, lots of voltage regulation options, fsb and multiplier setting etc.
Downsides are that it doesn't accept SDRAM and it has dallas chip. Otherwise it could replace my Pentium machine's motherboard. (I'm keeping 386, 486 and P1, one of each for myself and everything excess goes to trading and to museums)
Got it from auction site, probably it would have went to landfill, but i was able to save it for few bucks. 😀 (And it also had 2x8MB 72pin ram, never hurts...)
Reply 26838 of 52781, by The Serpent Rider
Tip: COAST module usually indicates early revision of the board, they are not AMD K6plus friendly.
Reply 26839 of 52781, by brostenen
Just bought one of these for my Amiga500 restauration project.
https://www.ebay.com/itm/Commodore-AMIGA-500- … WbCsN:rk:7:pf:0
