First post, by wiredaces80
Hello,
Any help with this would be greatly appreciated as I am dying to play these beloved games.
I have the following info:
Windows XP, Service Pack 3
AMD Athlon 2600+
512 MB RAM
Radeon 9600 128 MB Video Card
Directx version 9.0c
So far, I have tried the following things, none of which have worked:
1. Reduced and increased the refresh rate of a standard 60 hz from the range 55 through 65, none of which resolved
2. Under properties/compatibility, checked "run in 640X480" and "run in 256 color mode"
Please note this only happens with King's Quest 1 through 6...7 seems to be ok.
Any help would be very much appreciated. Let me know if I need to provide more info. I emailed the support hotline (uksupport@vgames.com) but have not received a reply.
Thanks!
