First post, by elcomadreja
Ok, I don't know if anyone here can help me out with this, but here goes. I have a Soundblaster PCI 512 and just found out it has a soundblaster 16 emulator for dos. (Running dos-mode in 98) The Shareware Table (Android) works fine, but another one (Enigma) doesn't. The sound keeps skipping beats and stuff. Strangely enough, the gameplay is still perfect though, so all is not lost 😁. I've done everything I can think of to free up memory (which did get it to run in the first place). I have Set up a seperate config.sys & autoexec.bat, & Loaded all the neccecary drivers and such into high memory &lowering the sound quality. I saw something suggesting to only emulate the XMS and not EMS...Anything else I can do? --thx
