First post, by thuhnc
upon startin' up DOSBox, everything went fine, until i tried to begin "the elder scrolls 2: daggerfall" (via free download on bethesda's website) . installation went perfectly, but when i tried to start the game it requested a CD. how can i bypass this?
Reply 1 of 4, by eL_PuSHeR
Rank Moderator
Moderator
[Title rewritten and post moved]
It seems you didn't follow Bethesda installation guide. Post your mountings.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 4, by Freddo
If you followed the official install instructions, the "wrong CD" error generally happen because of two reasons.
  • You're using an older version of DOSBox than 0.73, the solution is to download the latest release of DOSBox.
  • When you mount the CD in DOSBox, the "-label Daggerfall" part is case sensitive. You must write Daggerfall, not daggerfall or dAGGERFALL or anything else.
